grinding sounds!!
Discussion in 'The Garage' started by jmeti000, Aug 3, 2005.
  1. jmeti000
    jmeti000 Registered Member
    Jul 13, 2005
    33
    texas
    whenever i let on and off the throttle i get a grinding sound for the first couple of seconds and then it goes away...sounds lounder when i let off the gas, and gets louder as i go faster. i took it to the dealer and they didnt do a darn thing. they said my driveshaft was pretty steep from the lift. no checking fluids, dropping the differential over..etc...NOTHING!! the u-joints have been checked and they are all ok. apparently i have quite a bit of backlash. could this be causing the grinding?? and how do i fix it? any help would be great..
    thanks
    jacqui
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Do you have a 4 speed manual? Mine does the same thing and I have been told it was the input shaft bearing going bad on the tranny. Mine only does it at 45 MPH and higher when I let off the thorttle :doah:
  3. jmeti000
    Jul 13, 2005
    33
    texas
    its an automatic, but the grinding becomes really noticable around 45 like you said.
