Grinding!!!!
Discussion in 'The Garage' started by aj_tatted, Jan 6, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    i'm hearing some sort of grinding sound when ever i let off the skinny pedal. it's more noticable at higher speeds. i'm not sure if it is coming from the T/C, tranny, or rear end.
    Any ideas? Has anyone else ever had anything like this?
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    What T/C do you have? NP 205?
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    My buddies NP205 does that. What is wrong with it? sorry dont mean to hijack.
    Dan
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Low on fluid in the t-case?
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    mine does the same thing, I heard a while back in a post that if you have a lift but didnt get a longer driveshaft that it causes it dont know if is true or not havent got a longer driveshaft
  6. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    TWO THINGS ON A 205 COULD CAUSE A GRINDING NOISE,
    TOO MUCH ANGLE ON REAR DRIVE SHAFT
    OR
    THE CENTER GEARS OR CLUSTER GEARS (THE ONES IN THE CENTER THAT CONNECT THE TOP GEARS TO THE LOWER SET FOR THE FRT DRIVE SHAFT)INSIDE THE CASE
    YOU NEED TO TAKE IT APART AND SHIM THE GEARS, THERE IS MOST LIKELY TOO MUCH PLAY AND THE GEARS ARE 'WALKING' BACK AND FORTH
  7. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I dont know about on a 205, but on my 208, after I put on a lift, I noticed the same grinding noise whenever I let off the gas. I had to lengthen the driveshaft, lower the t-case, and convert to a cv shaft to fix the noise. I would say, just switching to a cv shaft should eliminate about 90% of that noise.
    -Harrison
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I had the same problem when I bent my transfer case mount. It jacked my driveline angles all up. I straightened it out and the noise went away. It was a 208.
  9. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    naw, it's a slip yoke. i think i found the problem. i pulle dthe shaft out and noticed a butt load of wear on the yoke. i think i have a blown bushing inside there.
    now i just need to figure out how to replace it /forums/images/graemlins/confused.gif, anyone ever had to do this?
