ground clearance w/14bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Oblin Goblin, Oct 14, 2000.
  1. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    How much ground clearance would I be giving up going from a 10 bolt rear to a SF 14 bolt? Can I use my current brakes and wheels with a SF 14 bolt?
  2. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    Not that much clearance difference. Guess it could make a difference in a tight spot. Brakes should come with the axle, but you will not be able to use the existing brakes on your 10 bolt. You will need new wheels, going from 6 to 8 lugs, unless you get the 6 lug. I think they made a 14 SF with 6 lugs, not real sure.
    good luck
    Go heavy or Go home[​IMG]
  3. mybeast
    mybeast Registered Member
    Oct 10, 2000
    95
    Simi Valley, Ca.
    Send the money and buy knew wheels. I've heard that the six lug 14bolt sf just aren't as strong as the 8 lug 14 bolt ff.
    When all else fails MASH the skinny pedal!
  4. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    I just got a 6 lug 14 bolt SF, and measurements say I will only loose about half an inch. Maybe a little more, I was under a guy's truck in the parking lot. [​IMG] It's a good axle if you aren't planning on running anything bigger than about 36". I'm only running 35's, so it's perfect. Hope this helps.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's [​IMG]
  5. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Mybeast, you're right, the 14 bolt SF (which can be had in 5-, 6- or 8-lug patterns) isn't as strong as a 14 bolt FF. That's because they are two completely different axles. The FF is well, a Full Floater, and inherently stronger that way, and also has a 10.5" ring gear compared to a 9.5" ring gear. A 14 SF is a good compromise for those of us who want total reliability without sacrificing ground clearance and aren't running anything bigger than 36" or so.
  6. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    When I installed my 14FF in my '85, I had 31's on my 10 bolt, & put 33's on the 14 bolt. I didn't loose any ground clearance at the diff, but it did stay they same. Hope thiis helps.
    Later 1-4x4
    LET'S ROCK
    Don't follow me you will get STUCK!!
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I went from a 12-bolt to a 14bolt FF.
    It hangs down quite a bit more. Not sure how much, but let's see - the 12bolt is 8.875 inch ring, the 14 is 10.5... The radius difference is just about 3/4"... The case is thicker... I guess I lost about 1.5" or less ground clearance. It's such a hog it looks liek more, but I don't think so.
    I'll more than make it up when I go to bigger tires.
    The 14b is stong enough, so even if you don't think it will clear something, just gas it and bang over.
    Please don't try that with your 10 bolt though!
    -- Mike
  8. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    If I remember correctly 4 wheeler did an article on this a while back and they said a 14 bolt sf/dana 60 was about an inch loss compared to a 10 bolt and a 14 bolt ff was 1.75 inches.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  9. mybeast
    Oct 10, 2000
    95
    Simi Valley, Ca.
    I've been told that if you go with the 14 ff you should go up two tire sizes to retain the same ground clearance as with the 10 bolt, so basicaly what everyone is saying. If your not going to run anything bigger then 36's you'll be alright with the 14 sf.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    I measured my 14SF and it is 1" lower than my 12 bolt so I am not sure how much lower a 12 bolt is compared to a 10 bolt.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
