Ground Hawg Tire Pressure
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5canuck, Feb 23, 2002.
  1. 88k5canuck
    88k5canuck Registered Member
    Mar 1, 2001
    26
    Ontario, Canada
    I just got some 38.5 x 15.5 x 15 Bias ply Ground Hawgs. Mounted on 15x10 aluminum rims.(No beadlocks) What psi should I run for offroading? It will be mostly mud. The tire sits pretty flat right with 26 psi in it. Should I go down to 20 or lower. They have stiff side walls so they should stand up well. Thanks for your responses. I am used to 35 BFG's which respond very nicely to airing down.
  2. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    You can probably go to 10 or 11 psi safely. You can go lower but you loose steering and can blow a bead. It's pretty hard to loose a bead with a 15 though especially in mud.
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps <a target="_blank" href=http://members.aol.com/fileholder2meg/projblazer.html>Clicky</a>
