Ground Hawgs Vs Boggers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5canuck, Dec 6, 2002.
  1. 88k5canuck
    88k5canuck Registered Member
    Mar 1, 2001
    26
    Ontario, Canada
    I looking at picking up a used set of 44" Ground Hawgs or Boggers. I am running only mud. From deep thick pits to watery mud(all types). No rocks at all. Will Ground Hawgs work just as good as Boggers. And also will cut Ground Hawgs greatly increase preformance. I was running 38" Hawgs and I think they worked good and lasted awhile due to them being a harder compound. Eastern boys give me your input.
    Thanks is advance.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I am not in the east but I have been in muddy places in different parts of the world.
    My advise to you goes like this:
    If you have the sloppy gooey mud, the bogger is better because it will work like paddles and the soft compound makes it easier when you hit a hard spot since it will flex on it.
    In the thick slippery mud (clay) you are better off with a hard compound that will digg and claw better than a softer one like the bogger which would not scrape any.
    Just my experience.
    /forums/images/graemlins/thumb.gif
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    No.
  4. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    They have always been the best, time and time and time again in the mud. Boggers are unrivaled in their paddle-based tread design... nothing even comes close. At least in my experiences boggers have been proven countless times. They apply more lateral (lateral not vertical) pressure than any DOT approved tire on the market... just look at the tread depth. The only thing more effective in the mud might be some sort of tractor tire or custom chiseled creation. The only thing a hawg has got over a bogger is longevity. They are made of rubber as hard as concrete, and will last a lot longer.
  5. cpwreaper
    cpwreaper Registered Member
    Nov 27, 2002
    16
    nowhereville
    hes right! i would take boggers over hawgs anyday. you cant beat the paddle type tread of the boggers /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  6. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    If you put hawgs on your /forums/images/graemlins/k5.gif just hope you never have to back through any mud!! Go with the boggers!
  7. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I love the Boggers as well. But I've had some bad luck with Boggers while trying to go back /forums/images/graemlins/mad.gif
  8. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Not from the east, but there is some good mud in Texas /forums/images/graemlins/thumb.gif Go with boggers, that's what everyone here runs that take mud seriously
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    i would go with the boggers, but if you really want hawgs, I'll sell you mine so i can get boggers!!
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    If you are going to stay with a DOT approved tire, go with the boggers. Unreal performance in the mud.
  11. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    If they are the same price, go with the boggers. I ran them both. If you do alot of road driving the hawgs will last much longer.
    As far as backing up, my 44" hawgs did great in reverse. One down side to boggers, some guys in the bogs do worse when they install 4 boggers. Not enough power to spin them all, so they run regular TSLs on the front.
  12. 88k5canuck
    Mar 1, 2001
    26
    Ontario, Canada
    Thanks for your posts guys. Some good input. I will go with Boggers. Diesel Dan had a good point about having enough power. I'm currently running a 1971 GMC 366 with a low stall torque converter. I'm able to spin my 40" mudders very well even in the deep stuff but it is no mud racing truck. It works till I get a 454. Does running Tsl's in the front help out with the front end wandering on the road and overall driveability of the truck? It isn't a trailor queen so anything I can do to increase the road manners and run nasty tires I try.
    Thanks again.
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    It does. I run TSL's in the front and boggers in the back. It drives much better. If I go do any serious mud, I put the boggers back on the front as I do notice a difference.
  14. bogginnut
    bogginnut Registered Member
    Jan 6, 2002
    82
    Jacksonville, Florida
    I can't beleive nobody brought up the size difference. A 44 Hawg is about the same size as a 39.5 Bogger. 44 Boggers are way bigger than 44 Hawgs.
    Sean
  15. s10350power
    s10350power Registered Member
    Aug 6, 2002
    16
    Maryland
    Yeah that guy is right the 44 boggers are way bigger then the hogs and are way better in any kind of mud belive me my frind had 40's hogs on a 2003 f-350 deisel and they sucks in snow and id bet they suck in mud
