Ground Hawgs vs. Super Swamper TSL's vs. Boggers
Discussion in 'The Garage' started by PsychoticDeadGuy, Sep 20, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Can someone that has experiance with all tires tell me about the wear for each one on the street and what type of off road they can handle? Thanks alot.
    update Item#: RV-36
    GROUND HAWG 6 PR 15/38.5-15 BLK. NYL. TBLS
    $928.00
    update Item#: B-109
    SUPER SWAMPER BOGGER BSW 38.5X11.00-15/6
    $872.00
    update Item#: SAM-94
    SUPER SWAMPER TSL BSW 38X12.50-15/6
    $756.00
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    is your search button broken?
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    u should turn this into a poll, u'll probably end up with better results
    the wear of a tire isnt really based on the actual tire but the allignment of the rig and what kind of lockers it has.
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Why not the 38.5 x 15 Bogger? Or 39.5 x 18? Those would be at the top on my list. Don't expect these tires to last long on a DD heavy rig. My cousin had Swamper's on his Z71 DD that lasted about 8 months. And when he did replace them they looked like drag slicks!! But with the choices listed I would go with the wider Ground Hawgs over the narrower Bogger's.
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    At least they are all Bias Ply :laugh:
    Off road there will be a clear winner in sand, mud, and rock.
    street wear 7
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Okay, Ground Hawg's wear like iron, they last a long time with street duty. Now for the bad, Ground Hawg's are not the best tires for rock crawling, very stiff sidewalls. Ground Hawg's have always worked great for me in the mud and sand.
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I love mine...
    also people's other pet peeve with hawgs are the fact that a 38" hawg is not 38"
    hell my 40" hawgs on 16.5x12 rims are 38.8" but I did that on purpose as they were supposed to be on 16.5x9.75 rim.... on the 9.75" rim they are supposedly 39" tall......
    I look at it this way.. if you want a true 38... look at the 17x40x16.5 or so... 38" may come out to 37ish.... :crazy:
