Ground wire trouble
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Greek, Nov 26, 2005.
  1. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    Hey im new here...been visiting the site for a while and decided to join up.
    Anyway on to the question. Im missing a ground wire on my drivers side. Theres no wire in my engine bay and its making my gas and other gauges go crazy. Can someone help?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That missing wired connection almost looks like someone added something and used that spot for a ground, then just cut the wire when the item was removed (like lights), you can just remove that missing wire connector. The other one with the wire IIRC is the ground for the light circuit.
  3. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Try running a ground from the back of the block to the firewall. That should ground the body as long as the battery is grounded to the motor (usually grounded to the alternator bracket).
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Usually the headlights ground there, as well as a wire to the negative battery terminal. However, the main chassis ground is supposed to be a copper braid (ground strap) from one of the cylinder heads or the block to the firewall. If this is missing or the connections are corroded, all of the body electrical stuff can get screwed up.
