Groundhawgs...Reverse rotation, fronts?
Discussion in 'The Garage' started by Tominator II, Mar 18, 2007.
  1. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    280
    South Park CO 80440
    I am thinking of reversing the direction on my front Groundhawgs. Anyone done this with these tires? I am really wondering about hwy manners . I drive the speed limit and above to trails. :D To my unscientific mind it seems like the tires will have better forward traction going reverse rotation from the arrow on the side of the tire.:rolleyes: I need real world results, not opinions . TIA
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    actually the traction will be worse if you swap em around. youll have good reverse traction but not quite as much going foward. dont really know why it works that way, Im sure someone else can explain it but for some reason directional tires like boggers and tractor tires dont have very good traction when used in reverse. plus I heard they ride rougher and wear quicker.
  3. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    its cause the dirt and mud just clump together in the middle cause the grooves in the tire feed it in. as opposed to running properly it feeds all the stuff outward. when you switch em backwards, what you actually doing is stuffing more crap under you tires and floating on top of the terrain and not biting into it.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dont think there is much mud on the highway;)
  5. goldwing2000
    goldwing2000 Guest
    I think that's kind of the point. You don't get in quite so deep and you still have some traction left to back your ass out.
    It might not be a bad idea.
    I dunno about driving on the road like that, though. Maybe swap them side-to-side when you get to the trail head.
  6. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    The only reason you would do that is if your truck's for muddin' and muddin' only. Like Obijuan said, with the fronts mounted backwards, the front end will float through the mud and not dig in. If you are doing any street driving I would'nt reccomend it.
  7. Tominator II
    Nov 5, 2005
    280
    South Park CO 80440
    Thanks for the input, I still might try it later just to see.
  8. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    driving on pavement will be no diff with them backwards unless u hit some rain, i have 38.5 hawgs on my truck and i have ran them backwards on the front and i have also criss crossed them and the criss cross seems to work descently, u make look funny but when ur boggin and u stop ur forward momentum it will back out, nothin better than not gettin towed, then u can try it again, i have not noticed any diff driving habits by runin them like this on pavement, go for it, have seen boggers ran like this on road to. not dd of course, but to get to the wheelin spot yes
