Grrr Body mount bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Sep 2, 2001.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    I am putting my body lift on today and the nut for the bolt right behind/under the drivers door broke loose. How do I get this sucker out?? Take a hole saw to the top side?? [​IMG]
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Unfortinatly, that is your best bet. If you know how to weld than all you have to do is after you put the new bolt on, take that piece you drilled out and weld it back in place.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Predator
    Jun 19, 2001
    130
    OKC,OK
    OK, and on the very back two bolts, do I need to drop the tank to get to the nuts?? 83 model.
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    You may have to. It just depends if you can squeeze something in betwen there or not.
  5. Predator
    Jun 19, 2001
    130
    OKC,OK
    I found 2 holes that the hitch was covering up. I think those are for the nuts. Now I gotta drop the hitch [​IMG]. ( And I thought I was gonna knock the body and suspension lift out today).
  6. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Ain't that the way it always goes? At least we have a long weekend!!
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  7. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    On my 82 we had to remove the hitch to get at the bolts in the rear . but did not have to remove the tank. My front bolts did the same as yours and i cut holes to get to them and welded everything back up when done.
    A BIG HAMMER CAN FIX ANYTHING.. [​IMG]
  8. Predator
    Jun 19, 2001
    130
    OKC,OK
    Progress report: Back two nuts are on so tight that I bent a 1/2" extension trying to get em loose. Had to resort to grinding the heads off from top. [​IMG]
  9. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    NO, KEITH!!! I am gleaming because I finished mine yesterday. I started at 10 a.m. and finished at 7 p.m. Let me tell you the greatest help (aside from a buddy of mine) was the use of a breaker bar. The only bolts that gave me a little bit of resistance were the last ones (the number 5 position). They came off easily with the breaker bar but had welded themselves just a bit with rust. Just a few hard taps with a hammer and punch. If you have any questions, just ask. I lowered my tank because I did not have to use a couple of OEM washers in that position. I have to say I felt very lucky to not have to struggle. I didn't even have the infamous "I wish I had paid somebody to do this" feeling and I consider that great success. Let me know if I can help. I also recommend you have a friend give you a hand. Oh! and I still need to get the tranny linkage welded. By the way, does anyone know if I can custom-make my own?
    "Constipated people don't give a crap!"
  10. BigTex
    Dec 27, 2000
    974
    South Texas
    By the way, I you ARE replacing your body mounts, right? I got the kit from ORD and they have excellent instructions.
  11. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I have to do the same to mine ! I have to cut out a spot and weld it back in ............ poly kits are real easy to do and good for it .
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  12. Predator
    Jun 19, 2001
    130
    OKC,OK
    Day two:[​IMG] finally grinded head off back bolt. Still won't drop down, prob stuck in bushing somehow. Found a 2" hole saw to go after the floor with. Last bolt. whew....this turned out to be a job!!!! Putting new poly body mounts in, old ones had seen their better days quite a few years ago. I'll try to post pics, later.
  13. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The bolt won't just drop after the head is ground off because its a carriage bolt with a 'square' part under the bolt head to prevent spinning whe its tightened. I used a small drift and drove it through the bushing...[​IMG]
    I dropped my tank after I got those bolts out...live and learn I guess.[​IMG]
    If you use a punch to get the bolts out use some vise grips or pliers to hold the puch while you hammer, it'll keep you from hitting your hand once in a while.
    Rene
