GRRRRR!!! I'm sick of electrical issues!!!!
Discussion in 'The Garage' started by colbystephens, Feb 20, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, went out to my truck, started up just fine everything works, turn on the headlights and only get marker lights. what's up with that? i tried a second light switch, all the fuses are good and i don't think that both headlights would go out at the same time. any thoughts???
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    bad high beam switch? click it a couple times and see if they start working.
  3. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Good answer!
    I'd bet on a bad high beam switch. I've had my lights go out completely when I switch from low to high and only come back on with a wiggle. Plan to replace it when I finish with the axle/lift stuff.
  4. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    I know how you feel colby, I have the same problem and they just stoped working on me one day :(
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Why not just replace all the wiring?
    As far as I am aware, all the diesel specific stuff is in it's own seperate harness...
    Takes only a few hours, then suddenly you have all new wiring, which will fix your wiper switch, light and ignition issues... Fix that mess you've made properly! :D
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i think it is that high-beam switch. i got them working, drove out to where i needed to be, came back to my truck they wouldn't work. screwed w/ it some more and thought it was a ground issue. great, that's easy to fix. well, shut off my truck again and had the same problem only wiggling my grounds didn't work. screwed w/ it for a while and got nothing. then i fired up my truck and figured i'd use my auxiliary lights to get me home, and as soon as i turned the truck on the lights came on... wierd. anyway, it sux. guess i'll try the high beam switch tomorrow evening.
    wiring is my spring break project! :) i think i'm going to relocate my fuse box... :D
