Guage cluster and wobbling steering wheel ???????
Discussion in 'The Garage' started by google, Jun 5, 2005.
  1. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    I want to replace my guages in my 81 blazer. Has anyone done this before? The guy that had it before me put in an oil pressure guage by cutting a hole in the plastic cover and grinding out the back. That guage doesn't work anymore though. But, the guage cluster is already ruined anyway, so is it a hard thing to do and is there a speedometer out there. Last thing is, my truck doesn't have the needle telling me what gear i'm in. What do I look for to fix that?
    Ok, this is the last thing. My steering wheel wobbels all over at the point of the tilt set up. Someone told me to take the wheel off and just tighten some screws to fix that. Anyone else done this? Anyone else have an idea that it might be a different problem?
  2. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    the shift indicator is controled by a small wire that is attached to the column buy a new one or rig it w/new wire
    There is a small roll pin(spring tension pin) that ocasionally breaks but usually it just wallows out the hole and you have to drill out the hole and install a larger roll pin, from my experience with other gm tilt-only columns, if its tele-tilt, may god be with you...
  3. google
    May 19, 2005
    805
    Arizona
    :D Thanks
  4. gambit420s
    May 17, 2005
    294
    no prob dunno bout the gauges though might be worth while to replace the whole cluster, or goto the aftermarket
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Here's an article I found for fixing the tilt: http://www.gnttype.org/techarea/suspension/t_steering.html
    It's a Grand National website, but I think all GM columns are pretty much the same inside.
    Mine was doing the same thing, so bad that it changed gears when I turned. I ended up just getting a new one.
  6. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    you looking to restore or fab?
    LMC has everything you will needx to restore.
    Jegs or Whitney good source for guages if you're fabricating.
    Fred
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If not that, check the bolts holding the column to the dash, those came loose on mine and the tilt would wobble.
  8. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    do a search on here for tilt column rebuild.
    you don't have to drill anything out and replace with larger, just go to the dealer and buya parts kit.
    you do need the tiltpivot pin removal tool, sorry don't remember the #, but they are less than $20 from snap-on website.
    You have to take the column down quite a bit further than just removing the wheel, but yeah basically, you just have some screws loos that need loc-tited and tightened up
    found this:
    Here is the infamous “GM tilt column loose problem” fix:
    Disconnect the Battery, Tilt the column to the full UP position, Pull the wheel
    Remove the locking plate, the large spring & the bearing cover (This comes off fine, but is a pain in the butt to get back on so I made a tool to put it back on)
    Disconnect the connectors for the turn signal switch, cruise and the "smart" switch
    Remove three screws that hold down the turn signal switch
    Gently pull the switch up and pull out of the housing folding down and hang by harness
    Remove the Ign Key buzzer switch and retainer clip
    There is either a screw on the right side holding in the IGN KEY LOCK or a slot in which you push a tab.
    Remove the screw or push the tab and remove the Ign Lock Cylinder.
    Most of us have been this far before into the tear-down.
    Next there are three or four torx head screws that hold the housing onto the tilt bowl, remove them.
    Return the turn signal switch back into the housing, do not put the screws back. This step is to give you some play in the wiring
    Gently pull up on the housing up and over the steering shaft. Tilting the shaft down will help but it puts the upper ball bearings in danger of popping out. The small cover for the tilt handle, the plastic push piece will all fall out
    There will now be a black bowl exposed. It has the bearings for the short shaft. The Hi Beam actuator rod will be coming through on the left side. There will also be a small rod through the top parallel with the floor. It is the sector shaft for the IGN Switch and has a small gear on the left.
    THIS IS IMPORTANT!! THIS IS THE PART THAT IS SPRUNG LOADED!!
    At the bottom is a small, about the size of a quarter, round silver plug with a square cutout in the center. This is the spring retainer. by tilting the column up most of the load has been removed from the spring. Take a #3 Phillips screw driver, put into the square hole. The object is not to go through this hole but to engage it. Push the plug down/in about 1/8 inch and turn counter-clockwise. There are two ears 180 degrees apart that retain the plug. REMEMBER IT IS SPRING LOADED!! Ease up until there is no load and pull out.
    The next step requires a small puller. I used small screws and vise-grips on one and a small crow bar on the other one !! They are in there pretty tight too !!
    There are two pins 180 degrees apart on the sides of the bowl. These are the tilt pivot pins and they need to be removed. Kent-Moore makes the special puller but I have seen other folks put a small screw in the hole and pull them out with Vise-grips. If the screws break you are hosed! The pins are harden and can't be drilled out if it gets screwed up.
    Once the pins are out put the tilt lever back in. Pull like you want to tilt the column. This releases the pawls from the retainer grooves.
    While holding them released, gently pull the bowl up towards you. The ball bearings are in danger of popping out again as they are disengaged from the races.
    You will notice that the upper shaft is connected to intermediate shaft by a white plastic ball socket. DO NOT BEND THIS TO 90 DEGREES OR IT WILL BECOME DISENGAGED!!
    Slide this to one side and two of four torx head screws will be exposed. I use a ¼” drive ¼” socket on a flex universal to gain access. This eliminates the danger of bending the tilt ball too much.
    If it's real loose tighten one from each side diagonally, That way the mechanism will seat and not bind. I recommend that you put locktite on them !!
    Going back together is just doing it in reverse with some extra steps.
    Reposition the tilt bowl on the shaft, pull back on the lever and slide on. Make sure the pawls engage the retaining grooves. The rods down to both the starter switch and the headlamp dimmer need to be lined up.
    Replace the tilt spring by depressing with a screw driver and turning
    To time the start switch the small snap ring retaining the sector gear, white or black plastic, and gear needs to be removed
    These will not be replaced until after the pivot pins are reset.
    Install these pins with a gasket hammer, SMALL! You may need to jiggle the bowl by actuating the lever disengaging the pawls
    Now time the ign rod rack with the gear and actuate a few times to make sure the Large cutout in the gear for the ACCESSORY position is timed. The rod has a tit that has to go into the racks crescent shaped area. This crescent shaped area allows the rod to be actauted from any tilt position when the key has been turned.
    Slide the turn signal housing down over the bowl, aligning the small tilt lever cover and headlight dimmer actuator. Small daps of grease will help hold this in position while trying to put it all together
    The rest is put together as taken apart.
    The Ign lock cyl goes in before the buzzer switch. The small tab on the lock cyl that actuates this switch needs to be held up in the close position. The IGN key needs to be out of the cyl for this to happen. Small dabs of grease will hold this up during assembly
    Another tip:
    Loosen the two nuts, maybe three that hold the column up to the dash frame. They are either 17mm or 15mm bolt heads. This will give you a little more play in the wiring.
  9. BrianDamage
    May 14, 2001
    753
    Alabama
