guages work till i pull headlights on??
Discussion in 'The Garage' started by boggerless, Jun 8, 2005.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    it's a 86 cab on a 79 jimmy frame.all the lights work also????
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    check the ground connection
    i had this problem with my aftermarket tach about a week ago, apparently the light connection acts as a ground while in the "off position"
    when i turned on the lights one night, open circuit on the tach... turned out to be a loose grounding wire
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I point to the ground. I had the same problem when I took apart my dash. Ironically, it was the ground attached to a wire, to one screw. Made my whole dash go haywire when the lights were on.
  4. boggerless
    May 26, 2003
    22,728
    96
    thanks guys. :D the grounding i will go.the grounds seem ok , but i noticed tonight that i stepped the brake lines onto the steering shaft. :doah: maybee i got a ground wire at a different time. :confused: :laugh:
