  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ok I think I need to replace the guages in my '78. The temp guage doesnt work, oil freaks out sometimes, and the speedo is finally takin a dump. I dont want to do Auto Meters, I already have thse in my '72. My question is where is a good place to get stock replacement guages? And about how much would they run, for all of em? Thanks.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I would start at a wrecking yard...
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    If you have a faulty ground strap for your gauges you will experience problems like that. Might want to check into it before you spend $$$$ on new gauges. Just a thought.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would hit the boneyards and if ya can't find any there go with some Auto Meters since they're probably cheaper than new OEM gauges...
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah, no faulty ground straps, one guage straight out took a crap. I have a set from the junkyard byt wanted new ones. The cant be more then my Auto Meters. Come on guys where else?
  6. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    page 49 of the lmc catalog. they average between 39 and 59 bones each. if you do not have an lmc catalog, shoot me a pm and i will provide you with all the details...
    LMC
  7. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I can check in my "box-o-guages" and see if I saved the ones from my 78 if you are interested.
    But if they are acting funny then replacing them might not fix the problem. Check your circuit board first to make sure you have good connections. Where the circuit card connects to the wiring harness is where you see bad connections.
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah LMC, I seem to have misplaced my copy. Only one guage is acting funny, one is gong bad and the other is dead. I didnt just want to replace 1 guage and have 1 guage and 4 faded ones so im gonna replace all of them. If the ones from your 78 are in good condition I might be intrested, thanks.
  9. dyeager535
    26,982
    191
    Have you actually checked the cluster like Goober suggested? With that many problems, it's much more likely that there are problems with the circuits feeding the gauges, not the gauges themselves.
    The gauges themselves can and do fail, but to have problems with all three in one vehicle, at the same time, is pretty unlikely, compared to having bad senders, corroded connections, and messed up wiring, any of which would still exist with new gauges.
    I've personally had really good luck with stock GM gauges, except the tachs I've had/have that according to my calculations are about 500RPM off.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Sorry, I should have been a little clearer I guess. The tem guage pooped out so long ago I cant remember, oil, about 2 years ago, and the speedo started acting up on tuesday. The only guage that might need to be checked into more depth would be oil.
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Is the quality of the LMC guages good?
  12. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I bought a spedo a few months ago, it seem to be working great. The guage is a carbon copy of the original. /forums/images/graemlins/waytogo.gif
  13. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    So far everything I've ordered from LMC has been top notch /forums/images/graemlins/thumb.gif!
    Bill
