guess the weight.
Discussion in 'The Garage' started by freeflow, Nov 28, 2005.
  1. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    im trying 2 figure out how much my rig is gonna weigh when i am done.
    here is what its gonna have.
    84 3/4 ton suburban
    14 ff rear axle
    dana 60 front
    40 gallon tank lol
    454 engine
    400 trans
    205 trans case
    warn 16.5 winch
    heavy duty bumpers probably 200 pounds a piece
    39"+ tires probably boggers :D
  2. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    hmmm is that with or without you eating mcdonalds beforehand?
    i'd have to venture a guess around 8k? although maybe 9k
  3. freeflow
    Nov 6, 2004
    274
    ya i was guessing in the 7000+ range
    its hard 2 guess i guess :haha:
    Im not gonna be doing any rock crawling at all, just mud and trails and some towing. so i want a heavy tough as can be rig. :D
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    8000... you have pretty much the heaviest drivetrain you can get without having a Cummins. :thumb:
    j
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  6. freeflow
    Nov 6, 2004
    274
    so does the 454 really weigh over 900 pounds?
    i pulled the engine and trans out 2gether by myself and it sure felt like a hell of alot, doesnt even compare 2 the 350,700 i pulled out of my last truck.
    Can i get boggers? can they handle the weight since im going for a very heavy truck
  7. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    I suppose it depends on whats bolted to it.. but I thought a complete 454 was supposed to be closer to 650-700 lbs. Lets see...
    14 ff rear axle = 500
    dana 60 front = 550
    40 gallon tank lol = 350 with gas in it
    454 engine = 650
    400 trans = uhhhh.... 200-250? dunno, never really lifted one...
    205 trans case = 200 with the adapter, shifters and crap.
    thats almost 2500 pounds in just drivetrain... throw in driveshafts and nuts and bolts and you're well over 2500 sans fluids. Those boggers are gonna weight about 125 a pop... so there is another 600+ pounds with a spare... bumpers and winch, another 5 hundy... Damn. The answer is: heavy as ****. lol! :thumb:
    j
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    The boggers and steelies shouldn't weigh THAT much. I have to push mine around regularly and I'm no superhuman so I don't think they weigh more than 100 pounds. Either way though, 100 pounds in tires isn't gonna make a difference on that heavy of a vehicle :crazy:
    I'm guessing 8-9k total. Basically, your trail rig is gonna weigh as much as my PSD tow rig. :eek1:
  9. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    My 39.5x15x15 TSLs on steel rims weigh exactly 123 pounds each... I seriously doubt Boggers weigh less.
    j
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    :eek1: I must be eating my wheaties. I'm gonna have 1/4" steel plate added in the form of beadlocks this spring too. I'll have to put 'em on a scale after I'm done.
  11. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Hmm, our F350 dump, 160" wheelbase with duallies and a 10.5' steel dump bed weighs in at under 7k at the quarry scales (6,740 lbs to be exact). I'm having trouble seeing how a burb, even with the mods listed, would come in almost a ton heavier. Afaik a 3/4 ton max gvw is 9k, and a lot of them are only rated for 7k.
  12. dubbyx
    dubbyx Registered Member
    Nov 14, 2005
    49
    Lubbock, TX
    the 454 w/o tranny should weigh 685... add in the greasy coating and the fluids and I'd say 705 would be pretty close... and the 350 should be around 535.
    I'd bet it'll be about 7800...
  13. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    Mine weighs 8100# with stock bumpers, 350/465/10b/14sf, me and my 4 kids, and about 250#'s of trail gear, and a full 31gal. tank. And it's the BASE mod., no power anything except steering.
  14. freeflow
    Nov 6, 2004
    274
    so it looks like it is gonna weigh more than 8100, im gonna have power windows .locks, dual batteries, over 100 pounds of audio.
    but i myself am only a buck forty, so i wont be adding much weight 2 it, lol
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Freeflow, did you ever get my e-mail? It doesn't seem to be workin' lately.
  16. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    does any one know how much a stock 3/4 ton sub weight? I thought they only weight about 1k more than a stock k5. and if your adding all of those bling parts they don't weight that much more than the parts there replacing.
    http://coloradok5.com/forums/showthread.php?t=139780&highlight=suburban+weight
    according to that thread a 1 ton k5 weights in at 5800lbs and a stock suburban weighed in at 5800lbs so I'm guessing a 1 ton suburban wieghts around 7000lbs give or take. not no 8000 - 9000lbs.
    http://coloradok5.com/forums/showthread.php?t=136459&highlight=weight
    here's another good thread. I'm just using both of those threads as reference
  17. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I think they are around 200.
  18. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    I KNOW that's what mine weighs, I use the scale @ work and it's within 20lbs and it gets calibrated every mo. ;)
  19. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    I'll guess about 6500-6800lbs. my '90 v2500 burbn weighed about 5800 before I made it a convert. :hack: :smirk:
