Guess what caused this problem...
Discussion in 'The Garage' started by gokartergo, Feb 8, 2004.
  1. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I was bored tonight.. Since I went as far as I can go with this motor since we found some new problems.. Just woundering how many people now what caused this..??
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    heavy foot by Dan??? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Usually that would be true.. /forums/images/graemlins/waytogo.gif But I never ran this motor.. I was getting it ready to put in my burb. When we ran into a few more problems then I thought..
  4. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Looks like the lifters and cam got no oil!
    Bill
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Is that one intake valve caved in? I've never seen that. Saw lifters like that though
  6. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Looks like the lifters got no oil!
    Amen
    and i might add looks like its time to hot tank the block to clean out all the oil passages
    My $.02
    R
  7. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    My guess would be the lifter & cam wear caused a really lean fuel mix which raised the temp. in that cyl. enough that the valve spring tried to pull valve through the head.I'll bet the piston was burned badly too. /forums/images/graemlins/thinking.gif
  8. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    with the valve the way it is it looks like it had way too much rpm and the timing advance and that cylinder detonated before the valve closed and slammed the valve in and then stuck closed and wore out the lifters. just my too cents.
  9. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I had that happen to an engine after a rebuild. Turned out two of the lifters were a little tight and didn't like going up and down with the cam. I still drove for a little while. I thought my carb wasn't working right so I'd fight to keep it running at a stoplight. Turned out was just killing it more /forums/images/graemlins/doah.gif
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I've seen a valve do that before. It was caused by a lean condition due to a vacuum leak at the intake manifold. It was in my grandparents' 89 C2500 with 150,000 miles on it. My Dad just cut the old valve out and put a used one in. Bandaid fix for a broken leg. We thought it'd only go 10,000 miles maximum but it kept going until around the 260,000 mile mark when the frame broke.
    I've seen cams do that before too. It's really hard to screw up a cam break in no matter what anyone says. It only becomes an issue with wild cams or really stiff springs. It's usually a poor cam that causes it in my experience. I've seen lobes completely worn off. I have a Cadillac 4.1L cam somewhere that the lobes are polished right off. Usually those 4.1L cams broke...
    To me, it looks like that motor has done been abused, mon. I'd be looking for other problems with that motor including the bores not being wore evenly.
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That's it... /forums/images/graemlins/thumb.gif
