Guide to dual battery setups
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gravdigr, Aug 7, 2003.
  1. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    There have been several posts on this so I am going to make this in hopes that people read it.
    First you must evaluate why you wish to run 2 batteries? Do you wish to run accessories without the rig running and not drain the battery? Do you want more starting power?
    There are a couple ways to hook up dual batteries. First you can just connect them in parallel. This doubles the available amperage while maintaining the normal 12v. To do this all you do is connect the pos and neg of both batteries together. It is recommended that both batteries are bought at the same time and are the same make or 1 may discharge the other. This is the simpleist and least expensive way to connect the batteries. Downsides are if one battery goes bad it will discharge the other in all probability killing both batteries.
    The second way is to use some sort of switch between the batteries. This has the advantage of separating the batteries so one will not discharge the other. The downside being you have to remember to turn the switch on and off and unless you like popping the hood every time you park will require running some heavy cable into your cab.
    Another option is the solenoid charging switch. If you have accessories that require a direct connection to the battery such as a winch, crane, liftgate, electric hydraulic dump bed or whatnot this is a cost effective system to use. Basically you run a line from the charging system through a ford style starting solenoid...and it seems the metal cased ones are good for this because they are rated constant duty...and to the battery. The switching side of the solenoid gets connected to the positive side of the ignition. So when you turn on the ignition to start your truck it closes the charging circuit and both batteries will be charged. While the vehicle is off the batteries will be isolated so you can run those accessories with confidence knowing that your starting battery will have juice. Another advantage to this system is that should your starting battery go dead for whatever reason you can use your jumpercables and jumpstart yourself. This setup also has the advantage of allowing you to run 2 types of batteries. so you can have a deep cycle as your aux battery and can run that pimp soundsystem at the next tailgate party for a long long time without the worry of fully discharging and damaging a starting battery.
    The final solution and the one most preferred is the isolator. Isolators can be found from $25 for the low end ones from JCwhitney to well over $100 from some online places. What an Isolator does is Allow your batteries to be connected to the same charging system at all times without requiring a switch and which will charge both batteries while still keeping them isolated from each other. This, like the solenoid isolation also allows the running of 2 different batteries.
    Now for an example in my Blazer I will be running a starting battery the will handle the running of the machine (starting, ignition, lights). I will have a totally separate and isolated circuit running of an auxilary deep cycle battery which will be for winch, aux lighting (fog lights, rock lights) power points both 12v and 110v through power inverters, and my stereo system and amplifiers. This way I can go to a 4 wheel party blast the tunes and run my spotlight without my rig running and still start my ride the next day.
  2. nickstegeman
    nickstegeman Registered Member
    Dec 11, 2002
    38
    Dallas, Texas
    Thanks a million!!!
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    ns /forums/images/graemlins/usaflag.gif
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
  4. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Yes please if anyone else has something to add please do so because lord knows I do not know everything. /forums/images/graemlins/thumb.gif
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Just curious, but if you have a completely separate circuit, how do you plan to charge the deep cycle battery?
  6. 88Silverado
    Mar 13, 2003
    2,664
    Battery Isolator or diodes.
    It will let voltage from the alternator or first battery flow to the deep cycle but not back.
  7. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    There is an article in Peterson's this month about this same thing they did an install on a Dodge and used a kit from a place called Wrangler NW well I called them today and asked some questions and they have a great kit for K5's here is the website
    www.wranglernw.com or check out peterson's this month and see what you think .....Jason
  8. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I am aware of that. But doing so doesn't create a truly separate circuit. I have a detailed custom dual battery write-up on my site. My point was the guy said he was going to have a completely separate circuit, not using isolators or switches or anything. I was simply trying to point out that if he wants his alternator to charge his dual batts, the circuits will have to be connected at some point.
    If I were to buy a kit, I would definitely go with the Hellroaring kit. It is more cost effective than the WranglerNW and just as reliable.
  9. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Not to steal your thunder but have you checked out the difference in the two I would go with the WranglerNW kit comes vechile specific and with the battery tray and is a complete kit nothing to buy other than the battery....Jason
  10. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    The only thing vehicle specific is the tray. Go to a yard or look online for a factory original driver side battery tray (came in soem K20's and any diesel rig). It is a lot cheaper and doesn't get more vehicle specific than OEM.
    Better yet, if you want something vehicle specific and all inclusive, take it to your local stereo shop and let them do it all for you. What was that saying again?
    Oh yeah...
    ...built not bought.
    Could've sworn I used to hear that around here. Guess times are a changin'.
  11. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I like my setup using a heavy duty, high amp relay. One battery is isolated by the realy as long as the key switch is off. It's the backup. When the key switch is engaged, they attach together, both do the starting and both get charged.
  12. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Actually I said
    Isolated meaning I will be running an isolator for charging both batteries and separate meaning the only thing the batteries have in common is the charging circuit. My starting battery will not run my radio, and my aux battery will not power my ignition. Separate circuits.
