Gun Drilling Axles
Discussion in 'The Garage' started by TONYP, Jan 7, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Has anyone done this to there 14FF axles, I'm sending some stuff out to the gun driller and was looking for info on doing it to my axles....what size hole did you drill all the way through.....
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    I never known it to be done but alot of the stock car guys around here do it with good reults are you breaking stock 14bolt shafts ??? if not it may be overkill /forums/images/graemlins/truck.gif
  3. TONYP
    Aug 13, 2002
    2,116
    so cal
    I can get it done free and was trying to trim as much weight off the 14FF as I can....read about it last night in the new 4x4 mag...
  4. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    That's cool let me know how it comes out I have the same rear and have a big block and 40" (soon to be 44" )and I might want to do the same. cool blazer /forums/images/graemlins/truck.gif
  5. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Yea I read that article last nightl...Liked that fluted 60 /forums/images/graemlins/grin.gif
  6. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    How do you like the trction lift in the front of your blazer I've heard mixed views on those things /forums/images/graemlins/truck.gif
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    when driving on the street it limits the movement of travel, and when I take it off road I remove the 2 pins to allow full flex on the front end,
  8. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    just read your post about the 14 bolt dics brakes did you have apattern or plans to make those brackets I have acces to a plasma cutter at work and could make some myself If you don't mind sharin' info /forums/images/graemlins/truck.gif
  9. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Guys.....if you gundrill a FF axleshaft, then gear oil will leak out all the time....
    -- Mike
  10. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Only if you drill all the way through
  11. TONYP
    Aug 13, 2002
    2,116
    so cal
    my set up uses the ford calipers, i could hook you up with all the info on them, but the guys here use the chevy calipers. let me know
  12. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    That's fine how much are those ford calipers again and what to they come on /forums/images/graemlins/truck.gif
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    I can see the weight saving, but won't taking out the material in the center of the shafts weaken them? /forums/images/graemlins/confused.gif
  14. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    no actually it's suppose to make them stronger kinda like a driveshaft or a pushrod I can't explain it exactly I just know it works I wouldn't do it to loose weight your talking maybe a couple pounds per shaft I mean 6 pounds of 400 of course I think it was smokey yunick that said don't look for 1 place to lose a pound look for 16 places to lose an ounce I guess every little bit helps
  15. TONYP
    Aug 13, 2002
    2,116
    so cal
    yellow,
    I picked them up from a junk yard with the cables and bracke hoses for $55....
  16. TONYP
    Aug 13, 2002
    2,116
    so cal
    what you would be doing is making a tube out of them, a tube is a lot stronger then a solid cause you now have two surfaces that would have to bent and or twist.
  17. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Okay, what year ford /forums/images/graemlins/truck.gif
  18. TONYP
    Aug 13, 2002
    2,116
    so cal
    I used ford t-bird 86-89 calipers.
  19. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think I would have the OD polished before I would gun drill them.
    I still have not found anything in my strength of materials books that would lead me to believe that gun-drilling would make it stronger. It would remove a bit of weight (not much!), allow you to get a deeper heat treat because it could be heated/quenched from the inside as well as the outside, and it would lower the moment of inertia a bit. I don't think you would gain anything from just gun-drilling it.
    Most failures start on the outside of the shaft (where the stress is the greatist). If you pollished the OD it would keep microscopic cracks from turning into axle snapping shafts.
    However sence you can get it done for free DO IT!
    14FF shafts are cheep. You can be the giny pig!
    Have one shaft gun drilled and the other polished and see which one last longer.
    Don't forget to run a stripe of paint down the shaft so you can tell how much it twisted before it breaks.
  20. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Here's a couple of pics. I don't understand the physics of gun drilling them, but a lot of the desert trucks run these axles without problems. That's 500-700 horsepower getting thrown at these things.
