Gun Storage?
Discussion in 'The Lounge' started by BlazerGuy, Apr 23, 2004.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Friend of mine is storing my guns while I'm in the USMC. He has to keep some of them in the garage. I'm worried about the humidity. Will it be ok if each gun is in a sock with one of those silica packets in it? Any other ideas? /forums/images/graemlins/waytogo.gif
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    hope he has it in somethhing safer than a garage!
    But if he must, An extra heavy lube of Breakfree CLP a gun sock, a bunch of silica packets, and then put all of it into a dark 3mil garbage bag.
    Bag will keep it sealed and harder to visually "see"
    Silica will keep excess moisture/any trapped moisture at bay. Sock will protect it from nocks and damage.
    P.S.: Stay safe out there. /forums/images/graemlins/usaflag.gif
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Can't say from experience, but I've read for long term storage, you should oil the poop out of 'em. I forget now, but I think I read the same thing from the M16-A2 manual when stationed in tropical climates.
    I'd stick mine in a safe with some ventilation, or some of those hard shell cases wih some silica packets.
    I'm a fairly new gun owner (had to plow forward during the 30 seconds the wife said "ok"), though, so I may be giving you the worst advice....
    BTW, I'm assuming these are rifles?
  4. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    They'll be in a cabinet and the real valuable ones will be inside the house. /forums/images/graemlins/waytogo.gif
    I will clean them real good and leave oil on them but here's another dilemmia(sp?):
    Should I store them horizontally or vertically? I'm thinking horzontally would be better since all the oil will go to the bottom of the barrel when they're vertical... /forums/images/graemlins/thinking.gif
  5. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Thanks /forums/images/graemlins/usaflag.gif
  6. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Whil this may be a bit extreme. Packing them in grease will ensure no rust damage is done. Thats what I would be doing in your situation. A little messy though /forums/images/graemlins/1zhelp.gif
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    The oil doesn't need to be dripping off them. It really doesn't take all that much lube to protect them. Especially if they'll be stored inside, in a semi-controlled climate. Besides, once you've graduated from boot camp you'll probably come home on your boot leave and re-clean and lube your guns anyway. Ask me how I know this... /forums/images/graemlins/whistling.gif
    My personal recommendation: Thoroughly clean all parts, punch the bores with an oiled patch, wipe down the barrel and all parts with an oiled cloth, re-assemble and work the action a few times to ensure lube gets distributed, and put the gun in a silicone-impregnated gun sock. My Springfield '03A3 has been stored like that for about 5 years now, and I have no corrosion at all on it.
    BTW, good luck with Recruit Training. Remember that it's only 25% physical, the rest is all mental. A positive attitude will get you through the shitty times!
  8. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Horizontal is better if you can keep from stacking them, and oil 'em up real good. Definitely put them in an air tight bag or container and add some sort of dessicant, silica will work but you need a good bit, not some of those little sugar packet sized ones, look online or at Academy, they have a little brass tube thing that works good.
    I left about 4 guns in a cabinet at my mothers when I went to college and stored them this way, and I don't think I took them until a couple of years later. Looked beautiful, still oily.
    Most importantly, put them in a place where no random jackass will shove them around to get to something.
  9. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Thanks, I go to San Diego on August 23... /forums/images/graemlins/grin.gif
    I'm thinking about building my own wooden chest(or something) to keep them in. I was at my friends house last night and the "gun cabinet" can only hold 10 guns. I was like "WTF?" I have 25+ firearms that need storing so I think I need build something for them.... /forums/images/graemlins/thinking.gif
  10. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Just realized I should've posted this in the "outdoor" forum...oh well, shithappens! /forums/images/graemlins/waytogo.gif
  11. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Look into buying a bore store sleeve for each gun. It's a sleeve impregnated with silicone. It'll keep your guns rust-free for a long time. They're less than ten bucks each. It'll run you less than $250 to outfit all your guns, small price for peace of mind. I'd freak out, and I have, if I ever found any rust on any of my guns.
  12. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I should be able to pick some of those up at the gun show. Thanks /forums/images/graemlins/thumb.gif
