guys with 12" and 8" rear leafs......
Discussion in 'The Garage' started by RootBreaker, Jul 25, 2006.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so back in 1997 a guy sold me 4x12" leafs and installed them...long story.. but anyway I got screwed on the deal... another long story...
    but all in all.. I am now realizing that I may not have 12" rear leafs.... so if you could....
    1. put a string from eye to eye....
    2. use a tape and measure down from string to bottom of leaf pack....
    what do you have?
    I have 12.5" with weight on the truck.... however.... I Know rear leafs already have a arch in them so im guessing I have 8" rears.....:doah:
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    if you do have 8" rears, get a shackle flip, then you'll be riding even, and riding high :D
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i had 8" rear springs but they are off the truck now
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    my truck was up high... but NJ lift laws do not allow it any higher than it is now....
    13" front leafs...
    supposedly 12" rear leafs....
    3" body lift
    old 40" hawgs
    was going with rockwells and 53's ... if NJ didnt change their laws....
    if you look hard enough there is even a front dshaft :haha:
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    How much rear block does the truck have?
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    had the stock tapered block... 2.5" on one side and 2.75 on the other
  7. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    all 12"and 10" lifts come with a 8" rear spring and the apprpriate block a 12" lift rear spring would be a custom deal
  8. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    No such thing as stock blocks on our trucks, GM used springs only so that block should be part of the lift kit. Also, I don't know of any manufacturer that makes an off the shelf rear spring larger than 8" so I would say you've got 8" rear springs with the accompanying block for a 10" kit. Custom springs are usually the exception plus I doubt anyone would have custom springs built and not eliminate the need for a block.
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    i bought the truck back in 1990 and did a body swap to it... basically it was a 1979 chevy 3/4 ton camper special 8400gvrw... maybe that is why there was a block...
    the guy i bought the truck from barely did an oil change less add a block to a truck that was not lifted.....
