H Pipe? or X Pipe....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blaze, Apr 12, 2000.
  1. 85blaze
    85blaze 1/2 ton status
    Feb 20, 2000
    117
    Corning NY
    Just wondering what your opinions are on these. Going to do one, we use xpipes on the race cars that i work on and they make a big difference, I have the motor otta a racer so... should i build an x pipe in?
    Blaze On ----- into the $$$ pit! Dang these things can cost ya alot!
  2. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I'm putting in dual exhaust soon and I'm going to use an h-pipe. I would love to use an x-pipe but I didn't think it would fit with the transfer case in the way. If anyone has done this, how? I'd like to know too.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    Proud owner of an 88 Jimmy
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I also considered an Xpipe when I installed my exhaust system. You're right, there's no room for them, unless you wanna lose clearance. I couldn't find anyone who could (or wanted to) build them, and the ones I found were extremely expensive.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  4. 85blaze
    Feb 20, 2000
    117
    Corning NY
    How far back should i put either of them.. as close the headers as possible correct?
  5. Grim-Reaper
    7,385
    Atlanta
    The crossover pipes do help. Like most of you have relized the issue is where. Typicly on a car they are placed right at the tail shaft of the tranny. Well you can't do that because of the case. They are most effective the closer to the manifolds they get on the X style aslong as your not having to make any real tight bends. On Our trucks the best solution would be to use the H-pipe if you can stand the draw backs. Again the most efective point would be near the manifolds. Again due to clearance problems this will be difficult. If your truck happans to have cats then they are located about mid way down just past the case. The H pipe should be located before them to be most effective.
    As you can see it's about impossible to put them where they need to be on our trucks. Best idea I can come up with would be to install flanges and do the H pipe under the tranny. The flanges would alow you to remove the pipe if you need to service the tranny. Down side here is you going to transfer some heat to the tranny. With a big cooler it shouldn't be a problem.
    Diging it in the dirt with my K5's
    Grim-Reaper
