H-Pipe
Discussion in 'The Garage' started by Elevator Man, Jan 22, 2007.
  1. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    I need to install a H-pipe on my blazer, but I can't figure out where to put it. I have true duals with turbo mufflers that are turned out in front of the back tires. the trany and t-case are in the way in front of the mufflers, will a h-pipe work behind the mufflers? Any info and pics you have would help me out a bunch.
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Actually, any pics you have would help a bunch. ;)
  3. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    H pipe behind mufflers would be worthless.
    For crossover pipes to be effective they need to be as close to the exhaust collector as possible. It's to help scavenging gases from inside the cylinder. Once you get the far back, it's not gonna do you any good.
    I always run crossovers on my street cars, but I just don't see enough room under the hood of my K5 to put an H pipe without sacrificing tons of clearance.
    You might pick up 10 horsepower with a mild motor, but I don't think it would be worth the extra clutter for you.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I set one of mine up this way. The "H" is easily removable for service.
  6. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    I really like that set up, I might have to try that for my K5 too! do you bolt a skid plate back up?(mine has factory skidplate for the Tcase)
