H1 lug nuts
Discussion in 'The Garage' started by RGV72BLAZER, Jan 23, 2007.
  1. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    i've been kicking myself in the as$ for the past week looking & searching & thinking about the lug nuts that go on the H1s. they're not the ones i have, to where you can see still the threads sticking out about half way. i don't think it's very aesthetically pleasing, so when i ran across the longer ones that cover the entire threads, i thought i'd really like to have them. anyone know where i can find them? also can these also be used on the 8 bolts that bring the two halves together...gosh if only i could remember who's rig had them.......thanks.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Readymix has that style on his H1s. I do not think you can use them for the two halves as the stud size is not 9/16-18.
    Ira
  3. RGV72BLAZER
    Jan 23, 2006
    2,425
    thanks a lot. i'll try to get in touch with him.
  4. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    arent the lug nuts 1/2, along with the h1 studs?? I know my lug nuts will fit the threads on my h1's .
  5. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    most dana 60f's use 9/16-18 wheel studs. d44f are smaller. i think 1/2-20. i have also seen dodge d60f's that had 1/2-20 wheel studs.
    any how as far as lug nuts go i use something similar to these, only thing is they stick out as far as the wheel, & farther than the lock out. i am worried they will get broke against a rock
    http://www.ezaccessory.com/Acorn_Lug_Nuts_9_16_Thread_Long_p/1210l.htm
  6. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I have the long cover lug nuts on my truck, they have them at Pep Boys. 9/16th is what you need, as far as the 8 bolts for the rims they are fine thread and I think metric so no you caint use the lug nuts, I tried to find some locally due to losing a couple and finally gave up, called USA 6x6 and had a spare set in a few days
  7. RGV72BLAZER
    Jan 23, 2006
    2,425
    cool beans. thanks for all the info guys. i have all the nuts already, but i want the longer ones at least for the wheels & i'll be running rock rings so i don't think smashing them will be a problem.
  8. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    that is odd, must be more than 1 style cause my h-1's have 1/2-20 standard thread studs.
