H1 rimes on a dually D60 and 14B. Can It be done
Discussion in 'The Garage' started by 84CUCV, May 18, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I have some H1 rimes now. Is there a way or do you still need to cut out the center and weld in a new one? Any help would be great thx mike
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    look for the stamp on the 12 bolt style they had the 2850 trailor version and the hmmv 3850 version!!! :D
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I run stock H1 rims on on my DRW D60 and my DRW D70 and it works just fine. White-Rhyno on here runs stock H1 rims on his DRW D60, and he has a SRW 14bolt in the back w/ a 3 or 4" spacer and that works fine too.
  5. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    im putting mine in very shortly and cant wait
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    14 bolt will be a problem. you need a Dana 70 from a dually.
  7. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    These are the pressed centers from USA 6x6, worked out perfectly, 3.5" BS
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and from the feedback i have heard from them, you are very lucky to have them.
    the H1 rims will fit a DRW D60, and a DRW D70, just fine.
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK whats the problem with the 14b?
    thanks guys
  10. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    There are no 14 bolts with a WMS wide enough to match the front dually D60, this will force you to run big wheel spacers in the rear (3"~3.5" wide). White Rhyno is successfully running this set up. Good spacers are VERY expensive to buy.
  11. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    get a van width or a dually(not cab and chassis).
    im using a van width with 2 inch spacers
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks for the help.
    mike
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    or run a Dana 70 and not have to worry about the weak spot that spacers create. :rolleyes: Dana 70s are in the rear of EVERY full width dually.
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK then the one i found is must be a 70 then! Sweet thx
  15. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Make sure it is the chevy 70hd :D
  16. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Spacers aren't as bad as a lot of people make them out to be, you get what you pay for and you have to maintain them just like everything else.
    As stated you'll need the D70HD, while these are in a lot of duallies there not in all of them. It'll need to be a 73-87(91) 2nd gen body style, full bodied truck - no cab chassis's and no 88+ C/K series.
    Added confusion - the D70HD was used in some (or maybe all) of the 88 and 89 C/K duallies but I'm not 100% sure of the complete application to look for. You can't go wrong with the 73-87(91) trucks.
  17. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks guys
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    when you consider you're taking at least 300 ft/lb of torque, multiplied by 2.52 (lowest auto 1st gear IIRC), then the low range of a 203 or 205)- x 2.0, multiplied by the gear ratio (im assuming at least 4.10s since there's a '60 involved) you come up with about 6200 ft/lb of torque. way more than i'd want to subject my wheel studs to with the added leverage of a spacer.
  19. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I would agree. Does not seam like a good idea.
    mike
