H1 valve stems
Discussion in 'The Garage' started by johnnychimpo, Apr 20, 2007.
  1. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    Probably been asked before, but I couldn't find it by searching. What is everyone using for valvestems on H1 12bolt wheels?
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    There was a couple threads on here just about 2 weeks ago about this. I believe the consensus was to drill the hole out and use regular valve setms.
  3. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    talk to BIG TRUCK he is running a set of valve stems with filters on the insides since hes running air soft pellets inside.
  4. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
  5. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
  6. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    what is wrong with the valve stems on the H1 rims?? there bad ass...i just kept mine on there.....all metal, u cant beat that...ive ripped out 3 on one trip..no more :D
  7. cwn anwyn
    Oct 30, 2002
    1,268
    6
    Falcon CO
    I'm switching mine out, cause out of 5 rims, I have 3 valve stems. One of which is bad. I havent found a place to get the actual stems, so I am going with something I can find easily.:D
    Z
  8. smalltowncowboy
    Jan 16, 2006
    503
    hermiston oregon
    BIG TRUCK just got the valve stems from the local tire shop (have to take the wheel to them) the valve cores he got from a specialty shop online with the filters on them.
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to try the hummer stealership for valvestems for my 12b h1's, if not then i guess ill have to do somesthign else
  10. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    out of the set of 5 I have only one has the mil. valve stem in it.
  11. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I just finished drilling and installing the new stems in my 12-bolts about an hour ago.
    I am using TR412s that I bought off ebay. No one local had them, so now I have 100 of them. I used a stepped drill bit I got from HF for $10 to drill the holes. I tried a few other ways but this was the best. The hole is 1/2" for the stems. Be careful centering the drill, the slot is a bit wider than 1/2".
    As a insurance against leaks I put a thin bead of black silicone around each valve stem. Then I stuck the stem in the hole from the back and gave it a tug with a pair of pliers.
    I will be assembling the wheels tomorrow after washing the magnesium dust off the run flats. There is a good bit on them from being cut down.
  12. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    Post up how they hold air. I'd like to do this to mine.
  13. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
  14. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
  15. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    any idea of a hummer stealership will have the 12b valve stems?
  16. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I think the ones I posted about are military only, but I am not sure.
