h1 wheels
Discussion in 'The Garage' started by 68on44s, Oct 5, 2006.
  1. 68on44s
    68on44s Registered Member
    Jan 30, 2006
    42
    arkansas
    Hummer wheels on 4wd's with big rubber.... Why does everyone want these wheels? I have access to these wheels, and was just a little curious why they are wanted so bad..
    thanks
  2. Jimmy4matt
    Jimmy4matt Registered Member
    Feb 7, 2005
    74
    Campbell, California
    Cheap 8 lug beadlocks that clear 1 ton brakes, I guess. They seem a little narrow and with a lot of back spacing for my taste.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    most either run them with dually axles (cuz of so much backspacing, no need to swap to SRW hubs) and have them recentered to a more usable back spacing. the 12bolt ones are more desirable than the 8bolt ones
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Benefit 1:
    Fits dually axles without any modification.
    Benefit 2:
    Inexpensive double beadlocks
    Benefit 3:
    Look badass :D
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    The double beadlock is huge...most beadlocks are only 1 side of the bead... Also they are dot approved beadlocks...the onyl ones that are;)
  6. WC
    WC Registered Member
    Dec 30, 2005
    13
    Kona, Hawaii
    I know of at least 2 other aftermarket beadlock wheels that are DOT compliant. (the DOT doesn't "approve" any aftermarket parts, the parts are only made to comply to DOT standards, I know it's only samantics, but this is the way the DOT doesn't became libel by "approving" parts)
    Humvee wheels do have a DOT stamp,,,,,,but they also have a "For Military use only" stamp,,,,,,at least the 8 lug one's that I have do.
    Anyway, bitch'n wheels if you deal with the scrub radius from the backspacing :D
  7. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    X2. I just ordered mine earlier today. I'm going to use the duplicolor chrome rattle can stuff on the beadlock studs & nuts and gloss black the rest. With some chrome lugs should look sweet...
  8. 1976Blazer76
    1976Blazer76 1/2 ton status
    Apr 17, 2006
    552
    Ridgefield, WA
    Heres a picture of my Blazer with the H1 beadlocks. Powdercoated black and the ring is powder coated blue, they look real good I think. I am running the dually front axle with a 4" spacer in the rear.
  9. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Looks like someone needs to update their build thread... :whistle:
  10. 1976Blazer76
    Apr 17, 2006
    552
    Ridgefield, WA
    :D Next week, still working on some updated pictures.
  11. 68on44s
    Jan 30, 2006
    42
    arkansas
    Thanks guys, But i havnt seen any h1 wheels that look like beadlocks... all h1's have them? Any pics and info would be great... Im trying to see if it is worth my time to pic some up
  12. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Mine are 12-bolt beadlocks
  13. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    I request pics of the H1's on the new crew cab body.
  14. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Here are my 8-bolts
  15. 68on44s
    Jan 30, 2006
    42
    arkansas
    So these arent the new hummer richy rich wheels are they? these are military wheels... I think i understand now.. dont I? And by the way a 5th gear wheelie on hwy 67 riding a hopped up banshee is a bad idea.. im spending my day on the couch with a whole lot of road rash.. lol
  16. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
  17. JC_
    JC_ Registered Member
    Sep 21, 2006
    98
    Indiana
    What did it take to make those work?? I have a M1008 that I would love to put those on... All info is appreciated!
  18. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
  19. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    2" spacers all the way around is all that is needed.
  20. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    i think H1s are the way to go, especially with DRW axles. I'm running DRW 60/70 combo, stock backspacing on my 8 bolt H1s, widened to 12", new orings and PVC inserts courtesy of USA6x6, new valve stems, sandblasted, primered, and painted gloss black. all in all, i have almost $500 in my wheels, which is not too bad compared to most of the other beadlock vendors. if i could i'd probably go with the 12 bolts, but too late now. also i'll be adding rock rings to 'em which will be another 115-200+ dollars. all for the love of airing down. :D
