H1's to recenter or not?
Discussion in 'The Garage' started by muddybuddy, Jan 27, 2007.
recenter or not?
  1. recenter them
    8 vote(s)
    50.0%
  2. run dually hubs and spacers in rear
    6 vote(s)
    37.5%
  3. im nekkid and dont care about H1's
    2 vote(s)
    12.5%
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im getting a set of H1's for the truck and was wondering which you guys would rather do, convert to dually hubs up front and get spacers for the rear, or have them recentered. since i dont have dually hubs to begin with, it might not be that much of a price difference between the two. which would you do?
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I'm running recentered hummer rims and they work fine but I think it maters on how much you rock crawl. If you do alot of rock crawling you might stay with the regular rim because if you end up bending one its alot cheaper to replace then having another one recentered. The only other problem I have found with my recentered rims is that they are not perfectly straight and tend to have a little bit of vibration on the highway.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    2" spacers all the way around
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have 2" sacers becouse it was easyer and cheaper. I only had to buy one set of spacers since I already had a set.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so with 2" spacers on the front there wouldnt be any interference?
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is correct. Readymix runs stock hummers, 2" spacers, and 39.5 Iroks.
    Oh it is on a SRW Dana60/14FF combo.
    Ira
  7. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I would say recenter them, of course thats what I have done to mine. I like that the spacer idea works but it still leaves you with around 5-6"s of BS. I would be into my steering box, leaf springs and probablly some other bad things.
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i know, but i like the idea that the spacers are going to be "cheaper". would you be afriad to run like 2.5-3" spacers front and rear on 60/14? that would put it at about 4-4.5" BS which would be perfect since i kinda want to keep my tires more under the fenders instead of outside them. what do you think?
  9. readymix
    May 30, 2004
    6,706
    26
    2" spacers are perfect on my truck. I was going to go with the 3" spacers but did not due to the cost.....
    Glad I didn't too, the 2" is perfect.
  10. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    I voted to recenter them.
    Ideally, the closer the center piece is to the center, the better. The H1's have soooo much back space ( like a corvette!) that I wouldn't run them 'as is'. Even with DRW set up.
  11. readymix
    May 30, 2004
    6,706
    26
    Why not?
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    are you running spacers all around?
    i think ive found a pair of 2" spacers for a reasonable price, so i just need to find another pair for the front.
  13. readymix
    May 30, 2004
    6,706
    26
    Yeah, 2" at all four corners.
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    can you post up some pics for me?:D i wana see how that looks. thanks man
  15. readymix
    May 30, 2004
    6,706
    26
    This all I have right now. I am going to be taking better pics pretty soon and will post them when I get them all resized.
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    crap, i completely forgot that was your truck:doah: im going to have to dig up that thread with all the pics. what are all of the specs in that rig? i really like it, i cant wait to get mine:D
  17. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    Because I'm anal-retentive :D !
  18. sapper
    Jul 11, 2001
    3,052
    NoVa
    You know what I forgot somwthing about my set up, I have a dodge 60, which is the same width as a 14FF. So the track width is right at what readymix has but he has more BS with a wider axle and I have less BS with a skinnier axle. So my prevous statement is untrue, unless you have a dodge 60. Any of that make sense??
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea i get you know. that explains why youd be hitting the steering box. i might try to move my steering box forward to keep my steering geometry as close to perfect as possible, and hopefully be able to just run regular hi-steer instead of reverse hi-steer
