H2 rims and tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by new2k5, Jan 22, 2003.
  1. new2k5
    new2k5 1/2 ton status
    Dec 16, 2002
    128
    south eastern PA
    i found a good deal on a set of H2 rims and tires and was wondering how well they would work on a 87 k5 with d 60 and 14 ff. since i am tryin to do axels lift and tires all at once i can only afford the 2" tough country add a laef kit. (for now) i was told a d 60 will give an extra inch of lift. is this true? i figure with 3" front and 2"" rear and some fender trimming i should be alright. i plan to go with a full 4" kit and 37's eventually.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The difference is spring pad height between a d44/10b and a d60 is approx. 3/4", and that is how much it will raise your front end.
    H2s are :rainbow: and I wouldn't want anything from one on my truck, but to each his own.
    I wouldn't recommend a 2 or 3" front lift. Go for a full 4" and you won't regret it.
    If you can't afford the $ to do the rear right, a block kit will work fine temporarily. Temporary blocks lasted, for me, several years until I did it up right.
    -- Mike
  3. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Correct me if I'm wrong - but won't the backspacing on these wheels be totally wrong for a K5?
    If I recall correctly, these wheels have a very shallow backspacing - you may want to look into this further...
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I think you're thinking of the Hummer (H1)wheels. The H2 aren't anything more than a body on a 3/4 ton chasis. The wheels are like any other GM truck wheel of the same year.
    Eric M.
  5. new2k5
    Dec 16, 2002
    128
    south eastern PA
    i dont know about the backspaceing thats why i'm askin. i found a set of 4 for 800 with barely any miles. considering the price of 17" wheels and tires i thought it was a good deal. yea i know i could go with 15's and grind my calipers but that just doesn't appeal to me. plus everyones got 15's i think they look too small for a big truck
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    But check out the stock wheels on any of the later model 4WD's. Starting with the IFS front ends, they went to wheels that have a lot of negative offset. The center face of the wheel is barely inside the outer edge of the wheel. /forums/images/graemlins/frown.gif The wheel centers are too small to fit over the locking hub stickouts on solid axles or the hubs of the 14-bolt FF. You also would have to cut out the centers of the clip-on covers that hide the lug nuts. /forums/images/graemlins/frown.gif
  7. new2k5
    Dec 16, 2002
    128
    south eastern PA
    thanks for the input ive decided against em. i just really wanted 17" wheels and i'm to broke to afford new. i am goin to buy a set 16.5's with generic33 12.5 froma guy at work for now. then get what i really want when i can afford a real lift
  8. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    i'm in the middle of a axel swap and I picked up new 15 rims from 4wph for 212.00 with 2.5 inch back spacing.
    this requires no caliper grinding too, btw I bough the modular style. My nieghbor likes them as much as his $2000.00 weld rims. And they have the..
    [ I am not a poser effect to them] /forums/images/graemlins/grin.gif
