h2 wheels and tires, gen 2 trucks? do they work?
Discussion in 'The Garage' started by camiswelding, May 2, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    the ads for them are all over ebay at really great prices...
    how do they look on gen 2 trucks... do they have a weird offset.... are they metric? do they work?
    35 bfgs and wheels for 600 or so (before shipping...which adds 175-200)sounds like a great deal
    /forums/images/graemlins/ears.gif
    cam
  2. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    As far as I know the hubs on our trucks will not fit through those rims.
    I have no idea about the lug pattern, it should be the same though, the H2 uses a 14SF in the rear.
    Then again I could be wrong, just found this; Ebay
    4" hub w/ 8 on 6.5"
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Someone showed me a pic of an blazer with H2 rims on it.
  4. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I've got a set on my 86 k30. See the pics in my sig. I've got the 315/70-17 bfg ATs as well. /forums/images/graemlins/thumb.gif
  5. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    very nice looking service body rig... especially for the harshness of Alaska...have any fit problems with the wheels and tires?
    thanks
    cam
  6. blasterD
    May 24, 2003
    410
    Anchorage Alaska
    The wheels and tires fit great. I am running a Skyjacker 4" lift. /forums/images/graemlins/thumb.gif
  7. txtough
    txtough Registered Member
    Aug 31, 2003
    39
    Lubbock Texas USA
    My 90 Surb with H2 Rims [​IMG]
  8. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    looks very nice /forums/images/graemlins/thumb.gif
  9. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    The specs on the H2 Wheels are:
    <ul type="square">
    *Wheel Size, 17 x 8.5
    *8 Lug on 6.5" Bolt Pattern
    *Back Spacing, 5-9/16"
    *Wheel Offset, +20mm (Positive Offset)
    *Hub-Hole Diameter, Aprox 4-5/8"
    [/list]
    By the looks of the trucks that have them installed, the extra inch (or so) of offset doesn't appear to be a problem. Anyone have any comments??
    I've seen a bunch of these sell with tires (315/70r17 BFG AT's) for under $500 /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif.
    If these will work then I'll buy a set and toss them on! /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  10. jayweb
    jayweb 1/2 ton status
    Jul 6, 2003
    213
    NC
    I asked this on another forum and was told that you had to open up the holes 1/4 inch or less and they'll fit. I am very interested in doing this, so any further info is appreciated.
  11. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    If you clean the rust off a 14 bolt ff hub they will fit with no modifications. The hole is for 3/4 ton GM's, so they fit like any other factory wheel on a 3/4 ton GM. I had my ford dana 60 front hubs turned down to match the 14 bolt OD, and now they work good on my ford axle too. /forums/images/graemlins/waytogo.gif
  12. Goober
    Apr 26, 2002
    2,222
    Have you got drums or disks on the 14bff? I remember hearing somewhere that the H2 rims don't clear the drums. Any idea if thats true or not??
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  13. jayweb
    Jul 6, 2003
    213
    NC
    what about a 10 bolt front (8 lug of course)?
  14. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    a guy at work has a them on his diesle chevy.they look pretty sweet.he got them for a good deal also.rims and tires i think for 400 dollars.
  15. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You do not need to open up the center holes. ALL GM 8 lug wheels have the same size center holes.
  16. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    13" drums. You heard wrong.
