h2 wheels/tires on a stock k5?
Discussion in 'The Garage' started by franco802, Dec 3, 2006.
  1. franco802
    franco802 1/2 ton status
    Oct 16, 2004
    270
    San Diego, CA
    Will H2 wheels and tires fit on my stock K5 blazer?? I have found quite a few sets for cheap(wheels & tires). I think they are 6 lug like our k5s. I have no lift, stock ride height.
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    nope, h2's are 3/4 ton 8 lug. H3 wheels will fit, as well as any 1/2 ton truck/burb/tahoe's wheels. I've picked up sets of 265/70R17's on stock gm wheels as takeoffs, with the stock AT tires, from $300 to $500 a set. Good way to get in tires if youo don't need real all terrains.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The newer 6 lug wheel won't fit over the older front hubs.
  4. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    No they wont fit over the hub but a little boring of the center will help them fit. Most six lug wheels will fit the rear end of your k5. Be careful with the front since some will not fit over the hub. You may have to "hone" the center out a little. Just be certain to try any wheel you get on the front before buying them.
  5. franco802
    Oct 16, 2004
    270
    San Diego, CA
    All great info!! Thanks for the heads up guys:waytogo: :k5:
