HACKING for 42s!???? ***1/2 DONE W/PICS!!!***
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Mar 17, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    <font color="red">EDIT: *** SEE BOTTOM FOR NEW PICS! ***</font>
    I drew the lines on the fender today to start cutting... but I realized all the stuff behind the fenders that needs to be cut in order to meet the same line on the outer fender. The wheel wells have to leave all together... a TON of support members inside the fender...
    I forget who made these pics, but this is the template I am cutting by:
    I see that they removed the inner wells in the front. I can't really tell what else is really needing to be, *ahem* "trimmed" to make those lines work.
    To all out there with 42s: How did you cut your fenders? How bad did you have to hack and whack your fenders? Let me know before I destroy my perfectly good fenders... /forums/images/graemlins/blush.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/1zhelp.gif
    Thanks...
    -Dan
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Re: HACKING (aka trimming) for 42s!????
    Those pics were made by yunit. I have the same pics printed out and going to do the same cutting this weekend in preparation for my 41" Michelin XLs I'm going to be running hopefully by the end of the month. I talked to him and he said you can leave the inner fenderwell by making releif cuts at the top of the inner fender where it meets the outside fender. That's what I'm going to try and do so I can still keep my inner fenders. Still see the mud a little on the trails I run. /forums/images/graemlins/thumb.gif
    Post pics when your done.
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Dude, like your ideas for trimming, but PLEASE! Go and buy some
    jackstands!!!! I want to see your blazer out on the trail, not read that it fell on you here! I use to use concrete blocks, and had one give way on me putting a 6" lift. I'm only telling you this as a friend &amp; fellow fourwheeler, and not to condem you.
  4. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Those are pics of someone elses rig..... not his. /forums/images/graemlins/wink.gif
  5. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Yes, those are yunits, it looks like he removed the inner fenders. How much lift and what size tires is he running?
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what is your lift?
    BTW, all the graphing in the world won't prepare you. it is different for everyone.
  7. jwduke
    Aug 25, 2001
    721
    Thank god! That really looks scary!
  8. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I cut about that much on mine, the rear is no prob, its the front firewall that always hits. I removed my inner fenders as well.
  9. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    With the inner fenders gone, how much CRAP do you get in the engine bay oif you find yerself in some mud??? /forums/images/graemlins/confused.gif
    -Dan
  10. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I've got a tired 6" lift, with a 1" body lift on ORD poly body bushings Zakk... how bad do you think I will have to hack the body up?
    -Dan
  11. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I talked to him (YUNIT) and he said you can leave the inner fenderwell by making releif cuts at the top of the inner fender where it meets the outside fender. That's what I'm going to try and do so I can still keep my inner fenders. Still see the mud a little on the trails I run. /forums/images/graemlins/thumb.gif
    Relief cuts where the inner meets the outer? I don't get it... can anyone help me here? YUNIT! Whats up man! I want to keep the inner fenders because I see A LOT of mud, and don't want to worry about having that crap all over my engine and electronics. /forums/images/graemlins/1zhelp.gif
    -Dan
  12. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I'd imagine you'd get tons of mud in the engine bay without the inners, in fact I think that's what they're designed for /forums/images/graemlins/wink.gif, Even with inners I get tons of mud in there with 31's...
  13. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    This is yunit's picture of relief cuts . I don't know how to explain them, but it's in the curves, you can't just hammer everything flat so you make the cuts and then you can bend the tabs to fit. Hope this helps.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  14. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Damn ears won't stop ringing.
    Right now the truck is on it's axles and I am ordering some big ass jack stands this week since the whole truck is being taken apart soon.
    In the picture I was running a 4" lift/2" body with 38.5x14.5x15 tsl/sx's, soon to be 6" suspension lift with 42's, front axle moved forward 2" and the rear moved back 3".
    Ok, the trick to this type of trimming is to cut the outer skin off first and remove it. As for the inner skin, you will have to measure it so you can get enough to fold behind the outer skin and support it. Did that make sense? Last you will have to make cuts so the inner skin can fold up, since the inner skin has a curve to it.
    If anyone is scared to do this, swing by and I will do it for you. /forums/images/graemlins/thumb.gif
    Sorry if I sound like a tart, but I am so tired right now. /forums/images/graemlins/1zhelp.gif
    More pics with the trimming.
    [​IMG] [​IMG] [​IMG] [​IMG]
  15. Michk5
    Michk5 1/2 ton status
    Jul 19, 2002
    139
    Misawa Japan until December...moving to Wichita Ka
    Are you sure in the pic there is a 2in body lift? Its just I don't see it, appears to be no body lift. /forums/images/graemlins/confused.gif /forums/images/graemlins/usaflag.gif
  16. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Sorry, in the pictures with the measurements there is a 2" body lift, the pictures that I posted were with a 4" suspension and 38.5's.
    I knew I was tired and missed something.
  17. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Peter,
    Did you use a sawzall? Or what? Your lines look very clean! Nice rig!
    Mike
  18. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I talked to Peter yesterday, and he actually used an air reciprocating saw. I don't have one of those, but he gave me the idea to use a jig saw with a sheet metal blade. I've already started cutting, and I am VERY impressed with the clean cuts I have so far, how stable the saw is compared to the jerky sawzall, and the jigsaw is real good with making turns thru the arches in the lines! /forums/images/graemlins/wink.gif
    Hope that helps! /forums/images/graemlins/cool.gif
    -Dan
  19. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Thanks Dan! Sounds like a great idea, and I do own a jigsaw. /forums/images/graemlins/thumb.gif
    Mike
  20. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    On the fronts do you have to trim the inner "skin" of the fender?? Im not talking about the inner fender but the inner part of the outer fender
