Had a weird idea...(6.2 turbo)
Discussion in '1982-Present GM Diesel' started by BigOrange90Jimmy, Feb 13, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Think a stock 6.2 could handle the boost from a stock import turbo? I'm pretty sure it could, but I think the exhaust temperature would melt the impeller in it. Whatcha think?
  2. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    I'm not an expert by any means (my turbo is a '87 Shelby Lancer - someday rice spanker), but I don't think an import turbo would make enough boost for our engines. I just don't think they're big enough. Maybe if you ran a twin turbo set-up... hmmmmmm
    Jon /forums/images/graemlins/burb.gif
  3. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    A single import turbo wouldn't make enough boost. Most of the import ones only make 6-10 psi on a 2 or 3 liter engine. You need to make 10 psi on a 6.2 or 6.5 liter engine. The next option is dual turbos, you could then probably make some acceptable numbers.
  4. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Sorry, forgot this part. All turbo impellers are steel, you don't have to worry about melting it like the aluminum pistons.
  5. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    So you're saying this could possibly work?
    Sorry, but are you referring to the pistons in an import, or the diesel?
  6. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    You don't have to worry about melting the turbo because it was from an Import. The impeller in the turbo is steel, you would melt the pistons in your engine before you melted the turbo. But yes, it could work, but i think a single turbo wouldn't make enough boost.
  7. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Think I should try this or just buy an aftermarket turbo for a diesel?
  8. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Depends on your ability. If you fab your own then you need to make the exhaust mounting and intake runners etc. If you simply purchase it then it all comes in a kit and you pretty much bolt it on. I like to fab stuff, if I had access to a couple import turbos that I knew were good I would build it myself.
  9. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Id just buy after market, at least you know its going to work. Unless you have the stuff lying around you can experiment with.
  10. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I don't even have the engine yet. Imports are big around here, and everyone is ditching their stock turbo's, if they have one. The truck isn't built either, so I can pretty much do what I want right now.
  11. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Just a couple of ideas. 1. A turbo from a Buick GN. 2. A turbo from a Cummings or a Powerstroke.
    I think the GN turbo would be on the the small side, I had one and it looks smaller than a Powerstroke turbo. No evidence though, just guessing.
  12. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    I do not think that the turbo would make enought CFM for a 6.5 l diesel.
