Had to shut off the water main on my house.
Discussion in 'The Lounge' started by 1-ton, May 19, 2006.
  1. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    I had a large 3/4" sprinkler PVC pipe on my front lawn break, and there is no shut off for the sprinklers system, so I had to shut off the water main to the whole house.
    I know how to fix cars and computers, but I have no idea how to fix anything on a house. Does anybody know how I can cap off the broken PVC sprinkler line, so I can turn my water main back on?
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Dig it up and replace broken part.
  3. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    Why didn't I think of that. :rolleyes:
  4. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    It really is that simple. Go to Homes depot and ask questions. you need a hacksaw, pipe cleaner, pipe glue ans a cap or replacement part.
    George
    ps they should ask what kind of pipe you're doing.
  5. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    I have a hacksaw. When you say "pipe cleaner" are you talking about a tool or a chemicel product? I will have to buy the pipe glue and cap. Will the cap be a smooth bore or threaded? How long after I install the cap will I have to wait before turning the water main back on?
  6. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    you dont need pipe cleaner, just wipe the end of the pipe clean and dry when you glue it, use blue glue, and just replace the piece of pipe that broke.
  7. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    There was a cap on the end of the pipe that cracked, which has water pressure going to it.
  8. smalltruckbigcid
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Homes has all the parts you need.........
    George
  9. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    It's really straight forword and a basic repair, if it was capped to begin with just go and buy the same parts and get some blue primer and some glue.Dood its a fairly simple thing to do, just leave it all dug up before you test it....;)
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If you are not gong to use it anymoe (it was capped, so I am assuming here) I would cap it near the house and save the digging. Just cut the pipe with a hacksaw where it goes into the ground.
  11. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    or you could turn your feed valve off to the sprinklers and turn your main on
  12. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    He says he doesnt have one....
    Dealing with PVC is real easy cut the broken section out and get you some couplers and a piece of pipe or if its the end then get a new cap, easy as that. Sling some primer on there and then the purple glue and you'll be ready to go. If you use the system get a valve for the main line and put that in right after it splits off the main line for the house...
  13. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    oops didn't see that i work lawn care so i just assumed sorry
  14. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    Well, I dug up the PVC sprinkler pipe, and sawed off a clean end. Then I went to Home Depot, and bought an end cap and blue glue. It is installed now, so I am just waiting for the glue to dry (directions say 2-hours in temps above 60 degrees Farenhiet), and then turn the water back on and test it. I hope it works. :confused: Thanks for the replies.
  15. chevyfumes
    Feb 24, 2000
    38,584
    266
    Did you get the primer as well, you need to apply that first????
  16. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    OH F*CK, what is primer? I ask the teenage girl (those are the only people they had) working at Home Depot, and she said that the cap and glue was all I needed.
  17. cbbr
    Jul 17, 2004
    14,681
    Just scuff it real well, clean it and glue the cap on. I have done that many times with no problem.
  18. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    It's the purple piss you put on before the glue.. makes that sh*t set up super quick... I was always told you HAD to use that.. But you may be alright..
    I just plumbed a baitwell system out of PVC the other day.... :doah: :haha:
  19. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    I cleaned the end of the pipe with a damp shop towel, and then just slaped the glue and cap on it. Oh well, this is not too hard to do. If this time does not work, I will just cut the end back off, and go back to Home Depot to get the primer and another end cap.
  20. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    I just turned the water back to the house, and it held. Thanks for the replies and help! :wink1:
