Hairspray,
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txguy, Sep 6, 2001.
  1. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    This may be something some of you know about, or not. Either way, I saw a show a couple years back about an 4x4 team crossing of the Artic. They had custom Landcrusiers. Anyway, on that show they showed a quick and easy way to fix a tire that has popped off the bead. They took a can of hairspray and sprayed inside the tire a little, and used a match or something along those lines to ignite the vapors. The mini explosion popped the tire back on the beads. I don't thinks its a method that is great for tires, but its a quick fix in a jam. Anyway, thought someone out there might like to know. I have read some on this site since I found it, think its a great place to gather/share info, and had not run into anyone mentioning that type of bead fix.
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I've had to use starting fluid on a payscraper tire before. Scary deal any way you look at it.
    Smitty
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yeah it's been mentioned before.... sucks to try it though and then end up with no facial hair. I suppose though burning yourself popping a tire back on is better then getting Herculiner on your hootus....
    How can I miss you if you won't go away? [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; 1 Timothy 4:12 &gt;&lt;&gt;
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Hootus.....LOL! [​IMG]
    BTW they used WD-40(or equivilent) not hairspray
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    we have used starting fluid to mount tractor tires that pop off beads for years...kind of an old time trick...i have done it a few times to mount some swampers or something i didnt want to pay to have mounted.
    Later
    Have you driven OVER a Ford lately?
  6. ArmyEd
    ArmyEd Registered Member
    Jul 1, 2001
    60
    Fort Campbell, KY
    need some help getting that off?
  7. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Hairsprays good for electrical connections too, its a lacquer and seals out moisture, used it on the rally car all the time during wet races or if there was going to be creek crossings.
  8. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Instead of Lacquer based products, which will dry out and crack your ignition parts, try Silicone spray, I use the foaming kind ...wash the entire engine down and get it clean then lather the puppy up....just keep it off the belts. It works great.
    White Knight
  9. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Makes sense, and could be an issue on a 4x4......I had good backing on the race car and would do a tear down and clean up after each race...you live and learn.
  10. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Oh geez it's not me... a. a hootus is a guy thing , leaves me out b. it's a post in the off topic you need to see... I bought it up to the top a bit back... it's way funny and the older members will know what I mean! [​IMG]
  11. ArmyEd
    Jul 1, 2001
    60
    Fort Campbell, KY
    ohhhh my bad, i thought that was singular for hooter doh!!!!!
  12. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    the craziest ive seen is some guy when he was airing back up pulled out a hose and pulled off one of his spark plugs and pluged in the hose to where the spark plug was and filled up his tires once he started up his engine ( i thought it was original...maybe not though)
    350, sm465, NP205, 14 Bolt w/Detroit locker(465 ratio), yucky ten bolt,38.5 swampers
    <a target="_blank" href=http://www.planettribes.com/theden/gontw/nsig.jpg>http://www.planettribes.com/theden/gontw/nsig.jpg</a>
  13. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    That's a "chuffer" - they've been around for quite a while, my granddad won't leave home without his.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  14. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yup... as CCG said... Hilarious. Stupid Ford/eploder owner at their finest [​IMG]
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I swear that hootus thing was on every website in the world. That's just damn funny.
    Tim
