Hand throttle cables.....hmmmm?
Discussion in 'The Garage' started by stallion85, Jun 24, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Ok, I have heard of hand throttle cables and have an idea of how they can be helpful. Could someone give me the lowdown and how I could hook something up on my rig? Pic's and part numbers welcome /forums/images/graemlins/thumb.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    All I know is that the person who did it, used a bmx bike brake lever. /forums/images/graemlins/dunno.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a brake lever doesn't hold a position like a shifter off like a 10 speed bike does. just clamp it on the shifter and run a cable to the carb.
    im thinking about useing one on my auto so i can bump the idle up a bit when in deep water.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am thinking it would be useful to keep the rpm's up while trying to push the clutch and the brake at the same time, while climbing a steep rock ledge and not wanting to stall and lose my brakes and steering /forums/images/graemlins/yikes.gif
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i was planning on rigging a manual choke cable to my shifter, but i kind of like the bike brake lever idea. that wouldnt be near as hard to mount as the choke cable either.
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have a hand throttle on mine. It is a brake lever off of a bicycle hooked to my 4spd shifter. It will only give me about 1/2 throttle, but works great when trying to take off on a hill or something... way better than trying to heel/toe the gas and brake! Cost was about 7 bucks, and about an hour to install...most of that was getting the cable hooked in a good spot on the carb so that it worked right.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Mine is an old Campagnolo bar-end shifter that's plugged into a cut off bike handlebar that's bent into a shape that allowed me to attach it to the trans shifter. I can operate the throttle control with my ring and pinky fingers while my hand is on the shifter knob. There's pics around somewhere online, I just gotta find them.
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I was just thinking about this last time I was trying to creep my way up a big boulder. I would love to see some pics!
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Pic's anyone?
  10. blaznjon
    blaznjon 1/2 ton status
    Mar 6, 2004
    153
    Seaside CA.
    I don`t have eny pictures,A buddy of mine had a 85K30 that had some kinda recovery package on it.It came from GM with a front winch that had a hand throtle under the dash in line with the gas pedal,it was a knob that you pull and then lock by turning 1/4 turn.It pulled on the gas pedal in the truck and mounted to the pedal support and under the dash.Maybe somebody could look one up.JB
  11. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
  12. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Here ya go man /forums/images/graemlins/waytogo.gif
    I used a hood release kit. It worked perfect. Just remember to lube the cable or else it gets a little hard to pull on /forums/images/graemlins/pimp1.gif
  13. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    I have also thought about this. I found a couple of things for the inside part. Pep Boys or a truck shop sells a very nice threaded knob type cable normally used with PTO's. Runs about $80. At a military surplus place I picked up one with notched detents for $3. For my underhood hookup, I was thinking of finding and using the little ball chain from the old style cruise control setups, but I haven't got that far yet......
