hand throttles
Discussion in 'The Garage' started by big83chevy4x4, Feb 28, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there have been a few posts, but none of the pics work anymore. i need some ideas for when i put my sm465/np208 in.
    is a bicycle shifter better or brake lever? i like that you can use the brake lever like a true throttle and gas it and let go and it go back to idle. but i also like with the shifter that it holds where ever you put it. maybe i could put both in:thinking:, thats just a lot of control cables :smirk:
    how did you hook it to the carb? i have a junk cruise actuator that i could use the end off of, lets me use the gas pedal without coiling up the hand throttle cable.
    what did you use and how close is it to the dash in creaper gear? doesn't look like there is too much room on my dads blazer.
    so lets ses some pics
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    This one does both. I can turn the dial to stiffen it up, or loosen it. It's a shifter made by suntour, works in friction and non friction mode.
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    Hopefully I can get all my stuff done that I need to get done so I can come help with the swap. But not to sure yet. I'll let ya know by friday TJ
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    I'm guessing the size of the carb return spring will determine how difficult it is to move the lever back and forth? Any issues with that?
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    where did you get that? a bicycle shop? what did it cost you?
    im not sure if i like how its mounted, i would like to hide the cable the best i can. it looks like it would stick out a bit. maybe i can find something that will work for me at the bicycle shop.
    let me know jess, looks like it will be this weekend. probably take the old tranny/tcase out saturday and do everything else on sunday when/if you get here.
  6. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
  7. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    No pics, but I have a small brake lever off of a bicycle on my 4spd shifter. It is a thumb throttle and is great for taking off on hills. I just ran the cable down the shifter, thru the firewall, and up to the carb and hooked it beside the throttle cable.
  8. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I made a mount for mine that clamps ont the steering colom (looks like an auto shifter) compleat with bike grip and full size brake lever. I works GREAT, when I'm in the rocks it gives me some place steady to rest my hand whille I use it so I'm not goosing the gas acsedentaly. I used a bike brake cable (uni. 5 FT, $3.00 @ the bike shop) then cut it to length and crimped on a solderless eye (red one with 1/8" hole) then used a small machine screw with 2 nuts on it to bolt it to an un-used hole on the carb. Just put the screw through the eye, spin on the 1st nut(leaving no interfearance with the eye) slide through the carb, and spin the 2nd nut on the back side and tighten.
    This is one of the best things I could have done for my trail rig ;)
  9. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Actually, I ran the cable down the shifter. It's out of the way and doesn't bother me a bit. I got the shifter from the link, but it's kinda old school, don't know if they still carry them. It was somewhere around 10 bucks though. I need to redo how the cable is mounted in the engine bay, that's my only problem. That's only because I have kind of a makeshift throttle cable bracket that I've been fighting with. When I loosen the shifter up, it's as if it's not even there, doesn't effect normal driving at all. It was a Suntour Pro XC Expert or something like that if you want to search for it.
    The stiffness of the throttle return does determine the resistance in the lever, just as it does with the gas pedal. It's not bad though. Plus this thing can be tightened up to stand up to any amount of pressure, or loosened to go back to idle when released. I like to use it to bump up the engine speed when I'm using my york.
    https://shop.sunrisecyclery.com/display/1605/0/
