handling with revolver shackles.....?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85k5blzr, Aug 16, 2001.
  1. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    So i have been planning a major suspension job on my K5. I am going to keep the 10-bolts because of cash reasons. I was thinking about putting on a touch country 4" front with the shackle flip in the rear. I wanted to run the revolver shackles because of their awsome flew ability on a 4" lifted truck. I was wondering though, if they handled bad on the road, since this truck is a daily driver as well. I was wondering if they caused the rear end to sway or if it stink bugged when braking? I was also wondering if a bracket or some kind could be created to hold them in place and keep them from extending and solve those problems? Any thoughts?
    K5 just upgraded to rig status! [​IMG]
  2. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I've got basically the same question. I did see a home-made "revolver" type setup on which a piece of square tube was tied in to the frame and had a shackle extended from it to the leaf. It looked solid, but when it comes to physics and dynamic geometry (tm), who knows.
    Hope someone with experience posts...
    John
  3. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Do a search on pirate4x4.com they have several large posts on this topic. But I read them and most everyone on that board considers them crap!
    79 Blazer 6"lift 38 SX's locked/4:56 <a target="_blank" href=http://www.keith.rockcrawler.com>www.keith.rockcrawler.com</a>
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I don't have any experience with "Revolvers".., but my suspension works on the same theory. I've had a "buggy spring" setup on the front for about 4 years, and my dropping "Springer" setup on the rear for about 3 years. I drive the truck 15k mi/yr - and it works well!
    The key is that anytime a "dropping shackle" suspension is used, some ADDITIONAL lateral support needs to be added to the suspension or it will feel "loose"... I run a "track bar" on both ends of my truck - and I've found that if it's set up right, it doesn't limit the articulation.
    You can see a snapshot of the whole assembly that I made for "ScoobyDann" on his page... He had already installed an ORD flip, so I made a special set of brackets for him.
    Marv
  5. CK5
    May 19, 1999
    21,622
    701
    CO
    Shawn had the revolvers on his Blazer and they made that thing sway like you wouldn't believe, I wouldn't use them myself.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  6. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Had as in past tense Steve?? That's what I thought he said a while ago that he was planning to ditch them because of the poor on-road handling. Glad I didn't copy him on that idea!![​IMG]
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  7. Grim-Reaper
    7,385
    Atlanta
    OMG! Marv is here!
    All right! It's about time you got on line here and shared your wisdom. Heck your about famous on CK5. I've passed your URL hundreds of times.
    Welcome aboard!
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  8. CK5
    May 19, 1999
    21,622
    701
    CO
    Yeah, he just took them off not to long ago, every time he drove to the mall the thing would have tons of body roll. he he
    Steve
    Bandwidth FREE ZONE
  9. Brian 89KBlazer
    779
    Ontario, Canada
    Maybe he needs (needed) to borrow your line! [​IMG]
    Brian
    89KBlazer
  10. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Re: OMG! Marv is here!
    Hey Grim...
    Yes, I finally made it on here. I appreciate all the times you referenced the Green thing!
    Haven't done much to it the last couple of years but drive it!... Now that gas is comin' down - I'll drive it for another 100k.
    Marv
