Hanger Drop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RIPPEDK5, Mar 23, 2007.
  1. RIPPEDK5
    RIPPEDK5 Guest
    Got my big rig 1982 chevy 3/4 ton with prit near 20" of lift, I want to have drop hangers in the front that will get me 6 inches or more of even lift and be strong enough for heavy abuse. Whats the best way to go about making them? Do I have to drop the rear of the front too? Too much lift already? I dont think so. Going for 54" or bigger tires with no rubbing or trimming (dont want to hack the body up).. Any good suggestions about the drop?
    Thanx
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I have nothing to add.
  3. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    Don't forget to upgrade to 10 bolts front & rear when you get 54's, if you don't already have them.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    1st question will be how do you have 20" of front lift as it sits?
    1nd question... do you have a body lift on it? that would be an easy way to pick up 3" safer then building a drop hanger in the front.
    and to add a comment yes you would have to build down both ends of the front springs otherwise your 6" hanger drop will only net you 3" of lift.
  5. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    20" s of lift? need pic's!
  6. Big91RustyBucket
    Big91RustyBucket 1/2 ton status
    Mar 10, 2007
    1,429
    New Lenox IL, Area (Chi-town Suburb)
  7. RIPPEDK5
    RIPPEDK5 Guest
    Sorry, Its a 14BFF in the rear, 10 bolt in front (soon to have axle truss on it) remember everything is more expensive in New England so Rockwells are out of sight on price. 18" front springs with longer shackles, Rear has 10" springs with 4" blocks, 4" ORD shackle reversal with Longer rear shackles(its in my profile) . Will get pics sometime this week. I like high trucks and dont care to cut my fenders and I dont think its gay.. Has no body lift. I have had no issue with this 10 bolt. I can replace 10+ 10 bolts for the price of a rockwell(after cost of rockwell and then mods to install it--its way to expensive!!)
    A body lift; maybe; to do it right though requires major wiring, shifter, and other modifications.
  8. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Whatcha gunna do 'bout the front driveshaft???
  9. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    B52 up front and a raised rear hanger from DIY or ORD, will need 52" springs.......uhhhh you will need at least 9 more 10 bolts because you WILL break everyone as soon as you take it off road.......
    You can run Rockwells stock and be alot better off than ANY 10 bolt o sould I sya 10 - 10 bolts.....
    Good Luck.....My burban is going on 50" Michelins....so don't worry about these HATERS..... You know how some of the Rock Jockeys get!
  10. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    I just want to see pics! Raise the truck to the clouds!
  11. RIPPEDK5
    RIPPEDK5 Guest
    I wish i could got to the moon but there isnt a big enough tire. Your right about the rockwells but $100-$150 can get me 2-3 front 10 bolts. Ill get more pictures when i can this week (probably friday --ill take good pics)... Sorry but im not really a fan of rock crawling.. I love the mud and it doesnt require alot of travel and slow speed crawler boxes. As for the front drive shaft I kinda lucked out but I didnt at the same time. My buddy makes driveshafts at a machine shot (BIG ONES) for Big Rigs, he quoted me $450 for just one shaft.. Which is ok but not- idk
  12. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    10 bolts aren't just going to break shafts off road... they're going to break balljoints on-road. This isn't going to be just stupid to drive offroad, this truck is literally going to be a danger to yourself and OTHER PEOPLE. 54's on a 10bolt is asking for a criminal negligence suit when a tire shucks off and kills someone.
  13. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    x2....
    If your running 54's on a ten bolt and think its ok then you have issues...:rolleyes:
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Rocks would be the best way to go, you should at least have a 60... You can get em cheap if you know where to look...
  15. RIPPEDK5
    RIPPEDK5 Guest
    Let me clarify, Right now I am NOT running 54" tires or 49" tires. I have 38.5" tall.. Around here a dana 60 is very expensive and hard to find; rockwells are fine but again serious expense and mods to have them... Plus my 14BFF and front 10 bolt will be trussed for added strength.. Dont you all forget about older FOURWHEELER and Petersens 4wheel & Offroad (early 90's late 80's mags) everyone had 38's-44's on dana 44, 10 bolts etc. even if they were sho and shine..call me nuts if you want but some of us dont have DEEP pockets or sponsors.. We use what weve got-this isnt te south or west, this is NEW ENGLAND sh*t is more expensive..
    Found a dana 60 front end out of a chevy $700-needed king pins, spindles, brakes, rust removal (major rust)
    $700 aint cheap for me
  16. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Run the 10b's, don't put alot of $ into it. Find a whole 1 ton truck for parts under $500. Or look for a old 2 ton Chevy, with all wheel drive, for the axels. I've seen junk ones go cheap, just not often. I think no one here, wants to see anyone get hurt, thats all. Just worry about fun getting spoiled. Still want to see pics, and be careful till you get to upgrade.
  17. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Dont tell me about new england, I live in Ct. As a matter of fact I have a dana 60 for sale. But thats besides the point... I spent 800 on mine and then rebuilt it... Is it expensive? Hell yeah... But your talking about running 54" tires... How much does that cost? I dont care if they were show and shine trucks either... doesnt make it right. A dana 44 or a 10 bolt, trussed or not still uses ball joints. They ARE NOT strong enough to handle a tire of that size.
    If anyone runs a tire that big on that small of an axles then yes, they are a fluckin retard... end of story. You are putting your life, and more importantlly the lives of others at risk, no question about it.
    But let not forget about 26 inches of lift comeing down the road either...:rolleyes: What the hell are you using for steering?
  18. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Damn, lighten up, this ain't PBB, no need to go slingin' names.....
  19. 79k20350
    Nov 22, 2004
    7,757
    Ct
    No, its not pirate...But I will call someone when they put someone elses lives at risk. Also I didnt call him anything, I said anyone who does... By his own account he hasnt done it yet;)
  20. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    X100
    And BTW, Trussing a housing is not going to help with bjoints and shafts breaking!
    But go ahead and jack the crap out of it and EVENTUALLY run those 50's.
    I will be waiting to here from you on how you totaled your truck.
    Meanwhile, I will be building my truck ONCE, even if I have to wait another year to SAVE up the money.
    I am unsubscribing to this one before I get really bent!
    I'm out!
