Hanging a 208 straight down..
Discussion in 'The Garage' started by suburban n progress, Nov 16, 2005.
  1. suburban n progress
    suburban n progress Registered Member
    Apr 15, 2005
    19
    Florida
    Is it possible..to take a 208 and hang it straight down.. i was told that the 6 studs and hanging the 208 down will work with the removal of one stud?? Seal over with rtv. Problem is lack of money for a 60 and a m37 divorce case and all the blah blah blah associated with the big boy turning toys but my suburban has 42's on it and a lot of lift where the front drive shaft is not happy..If i could hang the 208 down that would put my front shaft near stock degree again and make life easier just to go in 4x4 to pull out the local jeeps..IF this has been done id like to see or be explained how, im no rock crawler just a weekend recovery truck for the jeep guys or whoever gets stuck here in the florida mud.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Just get a clocking ring and do it the right way. It only cost about $67 bucks from Great Lakes Offroad I believe. Clocking rings are not for just moving the T-case up it allows you to rotate it any direction. The problem would be with your driveshaft rotating toward the center of your rig as well as how to shift the T-case.
    Ira
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    and it wont oil correctly.......
  4. suburban n progress
    Apr 15, 2005
    19
    Florida
    never thought of it not oiliing correctly...wow..hmm..if i could clock it past the crossmember that would be awsome..problem is cv hitting that thing.. other redneck way i was told was to get a spacer for the tranny mount and space it out at the frame like i was only lowering the xmember, seems ligit..How far can u clock a 208 down..
  5. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Eliminate the CV joint and just run single u-joints at each end. Single u-joints take alot more angle than a CV-joint.
    troy
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    How much lift is "a lot"? You may need to add a second, divorced case.
  7. suburban n progress
    Apr 15, 2005
    19
    Florida
    12'' of lift.. but i did however come into the ownership of a np200 so thats has probably fixed everything :D Now is the long process of getting shafts built
