Happier then flies on .....
Discussion in 'Pacific Region' started by 55Willy, Sep 9, 2002.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I got my 57's!!!
    off a 94 f@rd
    waiting for the "lowrider" shackle from summit to show up /forums/images/icons/cool.gif
    now to play with the fronts.....
    -Jeremy
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    the only lift you are gonna have is the 4 inch shackle flip? or 1 inch body and zero rate also or what? id really like to run just the stock 57" spring but i need to be 8 inches in the rear, frustrating.,
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    what do the lowrider shackles do???
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    it is longer then the stock shackle which is made for a 52" spring, the longer shackle will let the 57" spring extend farther then the stock one
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    yes i will be running a 4" flip with the fords, the low rider shackles which showed up the other day /forums/images/icons/cool.gif are 7.5" center to center where as a stock shackle is only 4". when I switch the ORD brackets from side to side(left on the right and vise versa) it will allow for the fords (57"
    ) to fit and also about a 1" more of lift. I am also running a 2" body.
    I have deisded to try the stock rear 52's up in the front minus the overloads. I'll be doing a play by play on the fronts as it seams to be a easy swap and moves the axle forward 1.5" at the same time.(thanks for the insight Rene)
    -Jeremy
    Josh to get 8".....
    flip (good for 4")
    low rider shackles(1.75 puts us at 5.75")
    zero rate(1" now up to 6.75)
    1" body(good for 7.75 total)
    throw in a degree shim and your at a solid 8" with nice soft springs.
  6. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    all chevy, no ford stuff and whats next jeep parts??
    No problem Rob, I'll gladly keep my tow rope coiled for ya....
  8. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    no problem i have a winch /forums/images/icons/wink.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  9. reddog64
    Nov 9, 2000
    3,325
    so using this lowrider shackle in place of the stock or borregonk5's you get how much lift, plus 57's and ???
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    you would have to do some cutting to get it to work with a stock set up unless you moved the current set up back like rene did.
    if you use the boreggos(sp?) set up you will have about 6" of lift with the fords
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ya, Borego's are pretty slick, thought about doing that years ago, but didnt like the idea of something that tall that skinny holding that much weight. BTW : right on /forums/images/icons/wink.gif
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    You said anything about ME holding that much weight??LMAO!!!!!!!!! /forums/images/icons/wink.gif
  13. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    lol /forums/images/icons/grin.gif i dunno what skinny is??? im tall, and stocky ( a,k,a, FAT ) 6'1 and 220 /forums/images/icons/smirk.gif
  14. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    i'm 6'1" 165lb lmao...let me turn side ways and jump behind this bean stock and you tell me if you can see me...lol
  15. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    so you think i should just go with the stock ford springs and not get a 2 inch skyjacker set....? i loved seeing renes tire stuffed in that fender well, i need to see my 39's in my fenders that same way
  16. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the stock flat ones flex better. go to the sky jacker site and round up the spring rating for the lifted spring.
    during my junk yarding trips i never saw one ford with out a rear sway bar or overload spring sets on it... they are nice and soft. like a shirt out of the dryer, LMAO /forums/images/icons/grin.gif
  17. reddog64
    Nov 9, 2000
    3,325
    hehe 6'1" 140 /forums/images/icons/smile.gif i got ya all beat!
    Oh and i can put away a large pizza and 6 pack pretty easy too!!! /forums/images/icons/crazy.gif
  18. reddog64
    Nov 9, 2000
    3,325
    so you think, if i used ford 57's, moved my stock hangers back, used boreggonk5's brackets i'd get the 6" I need to match the front???? /forums/images/icons/confused.gif
  19. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    yes and if it ends up low in the rear you can add a zero rate.
