Happiness
Discussion in 'The Lounge' started by surpip, Dec 21, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Is knowing that the spindles on the rear of your car are half the size of the 1000lbs trailer spindle that broke so easy on the Rubicon:eek1: :eek1: :eek1: :eek1:
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    May the pinion bring you joy and happyness :)
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    or knowing that your trucks front wheel is only held on by a nut on the top and bottom that is threaded onto a 5/8's inch shank...
    brakes are only held on by 5/16ths inch bolts threaded at one end opposite of the majority of force....
    your steering wheel although a slip fit is only held on by 5 to 10 threads....
    gasoline is being fed into your engine just past the exhaust manifolds, fear a rupture that could start a fire on the same side of the tranny cooler lines... oil fires are fun...
    ill stop now....
    Grant
