Hard Breaks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WakeBoard&4X4er, Jan 2, 2002.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I have been noticing that when every I hit my breaks lately I do not stop as fast I did in the past and it takes more force to press the break. Also, when I let go there is a sound like air breaks releasing when I get off the break. Is this normal with colder weather? 91 k5 W/ ABS that does not work any more.
    91 K5 and 73 Cobalt http://brettmcox.rockcrawler.com
  2. NeutralMan
    NeutralMan Registered Member
    Jan 2, 2002
    15
    vancouver bc canada
    i had same problem in a truck . does the brake peddle go down when you fire up the motor if not it could be the brake boster is leaking
  3. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    not sure, but do you mean then i start the truck does the break pedel move DOWN with out putting any pressure on it. I will check that when i go out ofter work. What did it cost to have your the brake boster firxed?
  4. NeutralMan
    Jan 2, 2002
    15
    vancouver bc canada
    you place foot on brack then start the motor the peedle should ajust . if it doesn't it could be the booster
    when it goes it like running manual brakes but twice the peasure to work them
    you can not fix it you have to replace it .
  5. NeutralMan
    Jan 2, 2002
    15
    vancouver bc canada
    you place foot on brake then start the motor the peedle should ajust . if it doesn't it could be the booster
