hard lines on 14blt ff??? on a 83 k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by down4thakrown, Jul 17, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    are the hard lines on a 14blt ff the same??
    how about the fittings that screw in too the splitter,distribution block, or whatever you want to call it and the other fitting on the opposite end that would screw into a rubber line that would be goin to a caliper for disc brakes with a banjo nut for a 7/16ths from a 77d44??
    the truck its on is a 83 k5.
    plz /forums/images/graemlins/1zhelp.gif
    all /forums/images/graemlins/ears.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have seen my buddies 14bff install , the block on the top of the axle fitted right up to the line on his truck . As for the rubber hose to the disc brakes , I hear of guys using chevette hoses to go to the factory hard line . /forums/images/graemlins/k5.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I used the hard line off my old 10 bolt rear when I swapped in my 14bff. It screwed into everything just fine. Should work.
    Harley
  4. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what year is your 14ff?
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    78 i think
  6. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Harley
    Same here, the brakes bolted right up. '77 14BFF into an '85 K5
