Hard lines on frame??
Discussion in 'The Garage' started by Poohbair, Jul 25, 2004.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Ok, so on the Pass side framerail of my 79 Jimmy there are 4 hard lines. They are in the way... 1 of them is the main fuel line... what are the other 3???
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    rear brake line, return line, and breather line for emissions stuff, is what I've figured out they are on my 84 and 85.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    what he said
  4. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    so do I need the return line and the emissions line, or can I dump them? I should at least be able to cut the emissions line off since I don't have emissions on the truck anymore...?
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you could but plug the line so no crap gets into your tank. As for the return line, if your fuel pump doesn't use it lose it. Though leaving the line would be nice if you ever want to upgrade to fuel injection, already have a hardline run for it just have to modify a bit. Personally I'm removing all but the brake line.
  6. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    You can ditch the emmisions line, thats the vapor recovery line that goes to the charcoal can on the core support, but you should then get a vented gas cap so you dont create a vacuum in the tank. teh return line you can get rid of and plug the return off the fuel pump or get a non return pump, but i kinda like the fact that fuel is always cycling thru the system, my exhaust runs not too far from the frame rail so the cycling keeps the fuel cool and prevents vapor lock.
  7. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    If they are really in the way could you re-route them with rubber lines? At least in the section where they are in the way. This would work for the return and emissions lines I don't know about brake lines though.
    -Chris
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    a return line fuel system definetally has its advantages, I would run a return line setup but I'm lazy...
