hard question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Skeeterlink, May 28, 2002.
  1. Skeeterlink
    Skeeterlink Registered Member
    Feb 11, 2002
    7
    Aight guys I got a hard one for ya I on my 78 k5 I have a winch that was on there when I bought it it's different though the spool turns horizontally instead of over-under like most, the letters HE are on the remote but no other names are printed on it. I need to replace the soleniods(they have post on both sides??? and no body carries them. Just wondering if any body has a clue what it is and where I can get the soleniods. Preciate it
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I havent got a clue what you have there, but you may be able to use Ford starter relays.
    Can someone verify this? I have seen some relays on older winches that just looked like Ford starter relays.
  3. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Maybe it's a Sidwinder winch? I don't know enough about winches to tell you much about them. Maybe someone else has some ideas /forums/images/icons/smile.gif
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    If it's real old HE could refer to "Hickey Enterprises"....Vic Hickey modified lots of Blazers and off road trucks back in the '70's.That's all I have....
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    It sounds like a Hickey Sidewinder. Those were tough made winches.
  6. NTAPHSE
    NTAPHSE Newbie
    May 6, 2002
    4
    Arizona
    about using a starter solenoid- i have a big compressor on my minitruck thats running off of 4g wire, with a 40 amp breaker and a starter solenoid out of a dodge deisel. i had a ford one but its not rated for constant power, so it burned out. if you go to NAPA you can look through a catalog of solenoids, just get one thats made for constant power, AKA 100% duty cycle. good luck.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Do you have any pictures? I am having trouble picturing this.
    Ken H.
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yup, sounds like a Hickey to me! LOL...I still have the sticker from them on the top of my radiator support in my '74. Unfortunately the winch isn't there anymore. Tell you what, If I can get the sticker off in one piece, I'll send it to ya! try looking Hickey Enterprises up on the internet and see what you find.
  9. Skeeterlink
    Feb 11, 2002
    7
    preciate the help I looked it up and sure enough it was a hickey sidewinder, now all I gotta do is find two soleniods that'll work
  10. AGM73k5
    1,246
    Portland OREGON
    The winch mounts vertical - instead of the standard horizontal. If you picture a standard winch - then rotate it 90 degrees - you've got a basic picture of it /forums/images/icons/smile.gif
    _
    _
  11. abusedtrucks
    abusedtrucks Registered Member
    May 11, 2002
    76
    Upsala , MN
    I like the drawing of the winch. That was pretty creative.
  12. abusedtrucks
    May 11, 2002
    76
    Upsala , MN
