Hard Start in Heat
Discussion in '1982-Present GM Diesel' started by Swanson52, Jun 13, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Have an 83 with the 6.2, and have been experiencing problems with it starting as the weather warms up. Injection pump?
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    If you're having problems with the engine warm, YEP - sounds like the pump is weak. If you add alittle 10W or ATF
    to your fuel (like a quart or two per tank) the fuel should thicken up and build pressure easier (and start easier).
    The pump needs build enough pressure to "pop" the injectors open at the precise time. It's not a fix but it can
    verify your diagnosis. /forums/images/icons/wink.gif
  3. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    I'll give that a shot. Thanks!
