HARD STEERING
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DMK, May 12, 2000.
  1. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    HAVE 87 K5 STEERING ON TRUCK IS FINE TILL TRUCK IS RUN FOR A WHILE. THEN AT LOW SPEEDS STEERING IS VERY STIFF. TRUCK HAS 150K. COULD POWER STEERING PUMP BE BAD, OR COULD IT BE THE STEERING BOX. FLUID IN PUMP LOOKS GOOD NOT BURNT. THANKS. EXCELLENT WEB PAGE...
  2. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    Could possibly be the belt is worn, glazed, or not enough tension on it. The fact that it runs well until it warms up leads me to think the P/S belt starts slipping as it warms up. And if you have recently replaced the P/S belt try tightening it again. I had the same problem on my truck where I changed the belt because it was slipping and squealing due to age, glazing, etc. A few days after putting on the new belt it started slipping again. Cranked the belt down some more and it has been ok since.
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    THANKS FOR THE HELP. WILL TRY THIS TOMMOROW. DID JUST PUT ON NEW BELT COUPLE OF MONTHS AGO.
  4. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Mine did the same thing when I got my rig.I ended up pulling the return hose off the pump and into a bucket.Then I had a friend start it and I ran about 5 quarts of fluid through the pump.Hooked it up and it's been great ever since.Don't forget to plug the return inlet on the pump before adding any fluid.
    OH yeah,Stay away from moving parts too.hehehe
    <font color=red>Wanna'keep wheelin? Get involved!
    Check the "Land Use" section of this board.</font color=red>
