hard to start when warm
Discussion in 'The Garage' started by tarheel, Apr 26, 2004.
  1. tarheel
    tarheel Registered Member
    Apr 11, 2003
    65
    GA
    hey guys. i did a search but couldn't come up with anything useful. /forums/images/graemlins/crazy.gif any how, my bone stock 350 starts great when it is cool even in cold weather, but it takes a few trys before it will start if the engine is still warm/hot. i'm runnin' a 4mv quadrajet. could it be a problem w/ the choke? HELP!!! /forums/images/graemlins/ears.gif
  2. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    is it a will not turn over or will not fire type of thing /forums/images/graemlins/dunno.gif
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Is the choke on when warm?
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Ditto. /forums/images/graemlins/thinking.gif
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I agree...is it hard to turn over when warm? I would definatley check the timing. We really need to know if its spinning over fast and not catching or if its just spinning over slowly.
  6. tarheel
    Apr 11, 2003
    65
    GA
    SORRY... ITS TURNING, BUT IT WONT CRANK. STARTER IS WORKING LIKE A CHAMP, BUT THE DAD GUM ENGINE WONT FIRE UNLESS I FLOOR IT AND THEN ONLY AFTER 2-3 SECONDS OF TURNING. AFTER IT DOES START, IT BILLOWS SMOKR FROM THE TAILPIPE AND RUNS ROUGH LIKE IT IS ALMOST FLOODED. WTF!!!??? /forums/images/graemlins/confused.gif
  7. tarheel
    Apr 11, 2003
    65
    GA
    OH YEAH... I ALREADY ADJUSTED THE TIMING AND PUT NEW SPARK PLUGS IN. STILL DOIN' IT. /forums/images/graemlins/thinking.gif
  8. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    IS THE CHOKE ON WHEN THE ENGINE IS AT OPERATING TEMPS? /forums/images/graemlins/thinking.gif
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Mine does kind of the same thing. If it sits for like 45 minutes, it doesn't want to start and when it does, it blows a puff of black. If it sits a long time or a really short time, everything is fine.
    I think it has to be one of two things:
    1) The choke wants to engage because the carb has cooled, but the engine is still warm
    2) The engine heat makes some gas spill over into the intake while it sits. If I waited longer, it would evaporate. I have been meaning to look in the carb sometime while it sits hot.
  10. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I had that problem in a couple trucks. Both times it was the starter getting too hot to spin fast enough. One on truck I had manifolds w/ duals. On the other it was headers with duals. On both rigs, I had to wrap the starter in the heat sheild stuff. After that, they worked like a champ. May not be the case here, but that is what it was for me.
    On this blazer, when I had the exhaust put in, I asked him to run it as close to the frame and as far away from the starter as possible. No issues with this one.
  11. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    It could be that the carb has leaky metering wells,allowing fuel to drain into the intake.They had a kit to fix that problem years ago,a little foam dewhickey you stuffed under the bottom of the carb.I think you can use epoxy too.There is probably some info on how to do this on this site somewhere. /forums/images/graemlins/grin.gif
