Hard to steer at idle
Discussion in 'The Garage' started by Scott A, Jul 16, 2004.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    Fluid is good and I put a new belt on because I thought it was slipping. Maybe it's time for a new pump. I'am running 37" Hummer tires. I do have an edelbrock cam & lifters, maybe I am not getting enough vacuum with that cam???
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    vacuum should have nothing to do with the steering pump. I was experiencing the same thing though on my 87. I replaced the pump and the belt and it it better now. Be sure you tension the belt enough.
  3. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    I guess I will try a new pump. Autozone has them for $52.99 Any tips on installing a new pump?
  4. readymix
    May 30, 2004
    6,706
    26
    You will need the correct tool for removing and then reinstalling the pully. Other than that it is pretty straight forward. I only paid 45 for mine at auto zone about a month ago.
  5. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    What is your idle speed? Is it possible that it is set too low? I had a similar problem, and it was caused by the fact that my engine wasn't turning fast enough to feed the pump.
  6. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    I think about 900 RPM's
  7. diesel4me
    Jul 24, 2003
    17,579
    945
    Massachussetts
    37's are pretty big tires,they may have stressed the pump to the max,especially if it has high miles on it--before you change the pump,you may want to check the power steering hoses if they are original or old,they might be collapsed inside,restricting the flow to the steering box(the high pressure hose mostly),if the hoses are new or in good shape,its probably the pump getting old,and running a lower than normal pressure. /forums/images/graemlins/crazy.gif
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    [/ QUOTE ]3
    Go to a junk yard and pick up a pump if you can. I changed mine out and tried to take the pully off first but just fuggered it up. The dealership wanted some outrageous price for a new one. I paid $25 for a pump with pulley at the local JY. Turned out it was kind of new in the truck we pulled it from, it had a reman sticker on it!
  9. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
  10. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
