hard top cracked in the back
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Oct 24, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, my hard top has been cracked in the back since i got the truck. The crack is on both sides just a bit lower than the top of where the window rolls up. Is there any way that i can make this a bit stronger, my top shakes a lot back there when i get going down the freeway with the window down
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You could 'glass over it, but hardtops are a dime a dozen - I'd just look around for a new one.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. B75k5
    B75k5 Registered Member
    Mar 5, 2000
    53
    Southern Calif
    Sorry but I don't know of any place that sells new 1973-1975 Blazer tops......Maybe you can find a 1976 on, but if you know of a place let the rest of us know. I could use one myself.
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Besides that, most '73-'75 tops are cracked also if they haven't already been fixed. Fiberglass is pretty cheap and easy to work with. I'll be fixin' mine someday......unless I find a good one for a dime....
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  5. Grim-Reaper
    7,385
    Atlanta
    the 73 and early 74's were prone to this. The top was redesigned in 74 and has overlaping seams to prevent cracks and breaking appart at the seams. you need to find a used late 74 or 75 top. Hate to tell you this but I have 2. Sorry neiter is for sale at this time. One is to replace mine that is also cracked from body flexing and cracked at the rear window bottom corner and angles off to the back. As soon as it really lets go I'm cutting it up to try out a few things and the other top will remain unmolested for winter use.
    Women dig dents and flat paint!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    There's two in the boneyard up the road - look to be in good shape. There's been several for sale on here during the last few months too.
  7. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    when you use the fiberglass you need to leave the 2 seems open if you glass over them they will tend to crack and it looks even worse then before(my brother did the glass thing but covered over them and it cracked) just my 2 cents
