Hard Top Hell
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zebomalenkno, Aug 23, 2001.
  1. Zebomalenkno
    Zebomalenkno Registered Member
    Aug 23, 2001
    5
    I got my first k-5 last week and ever since i have been thinking of taking the top off. Everyone i talk to says that it is virtualy impossible to get the thing back on and not have it leak. It there a way to weather proof it when i put it back on? Help me
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Only if the seals are pretty trashed will it leak normally - besides that, it probably needs a new cab seal anyway. Gives you a good excuse to go ahead and change it[​IMG]
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I heard the same thing....
    I've taken mine off since i have had it for the past month over twenty times....and believe me down here in south louisiana we get them big ol' drops of rain....and its yet to leak yet even when its not bolted on
    If you do get new seals for it you can extend the life of the seals by putting a coat of petroleum jelly on them about once a month
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You haven't filled out your profile yet(better do it soon[​IMG]),but if you live in a warm climate, you should consider ditching the hard top and running a soft top like the CanBack.........
    Man, if I lived somewhere warmer that hard top would become a workbench in my garage[​IMG]!!!!!
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've taken mine off lots-o-times and have yet to have it leak
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    The first time I removed my top, it was 20 years old. Seals are still good and no leaks. You should try it.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if it needs new seals it will leak, they are not cheap but a layer of matching color RTV will take care of it if they are not to bad. also if they are real nice you can put a bit of vasaline on it to make it seal a bit better. make sure that the fiberglass has a nice coat of paint on it where the jelly touches if you do it that way though.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  8. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    I've had mine off lots of times and never done anything to the seals. I only use six bolts on my top now and its never leaked, just tighten the front cab bolts first.
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  9. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    After I removed the bolts from my top I sprayed the seals with 409 (kitchen stuff) and gave it a few minutes. The top came right off. Don't forget the two bolts underneath the rail near the back!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    When I've had tops off of my K5's in the past, I've always cleaned and waxed the sealing surfaces on the body before reinstalling the top. I also clean the weatherstrips and put some weatherstrip dressing or Armor All on them. This makes sure that there's no dirt, grass, leaves etc. that can get trapped between the body and weatherstrip and cause a leak. In 20 years of driving K5's I've never had a leak around the top. [​IMG]
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    My 85's top was first removed (I'm pretty sure) in 2000. At first it would hardly budge since it had been cooked on for years. But with my shoulders on the underside of the roof and feet planted on the bed bottom, I was able to apply a couple hundred lbs of force to the roof and finally it started to snap and pop loose in different places. Since then I've had it off several times without doing anything special to the original seals except cleaning and waxing the bed rails (they looked hideous) and I have not found a drop leaking anywhere since.
    I heard those "never seal again" rumors too, but I think that they are just an old wives tale (except that there are probably not too many old wives who sit around talking about blazers...). Maybe they were started by Bronco owners or maybe they go back to the original full convertible top Blazers, but the setup on the late 70's/80's Blazers is pretty good: a compressible rubber seal compressed all around by several bolts between two rigid surfaces.
    <font color=green>If a K-5 is "Built not Bought", why does this stuff cost me so much money? [​IMG] </font color=green>
  12. dyeager535
    26,979
    As well, there is a specific tightening sequence for the tops, once removed, that MAY help make sure it is reinstalled correctly. Believe that is in the GM service manuals, although it may also be in the owners manual.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  13. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Another suggestion would be to give the seals a good coating of Silicone, and in the back on the top of the rails are two pins facing up take 'em out and the top will slide on and off much easier!
    White Knight
  14. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Mine has leaked since I got it so I have no problem with taking it off.
    Good things come in small packages. Good things come to those who wait. So, if you're waiting for a small package, that must *really* be sweet.
